Question is what if you all the above and you still have jittering in the pitch servo and cannot get rid of it no matter what and you manual tune and autotune but the jitter remains its like its hunting where ever the pitch is. I have tried to balance the camera different positions and have tried to change the center point manually with no help in getting rid of the jitter. I have also change dummy pots from one the other no change the roll always works great with no jitter.
Michael64
Michael64
My AV130 is working well with 1.2.2 & dummy pots/wire harness simple mod. There seems to be a few people that are still having problems with the skyline. I suggest everyone having issues read the official guide pdfs on PH's website and check both your gimbal and wiring carefully. Personally, i think the first setup with the mod you should not do the auto tune, as you are really testing your dummy pots and wiring before you are tuning your gimbal.
If you error in any of the process, of course you will have issues. One big mistake to look out for is after any tuning malfunction (that makes the gimbal go nuts) check the skyline is still tight on the gimbal.
Remember to remove the tilt belt and servo gear wheel when first manually leveling the skyline as it saves a lot of strain on your equipment.
