1)Dedicated 6v BEC for skyine.
2)Skyline powered from 2s 7.4 ( via above BEC) BEC has several loops in ferrite ring.
3)Sony nex5 flush to the tray.
4)Tilt only controlled with Rx (same Rx as flight controller
5)Windows 7 running Toshiba Satellite P500 ( 18" monitor , yeah!)
UPDATE!
5 test flights after reverting back to 1.2
ALL is as good as it has ever been. Maybe a little better, I upped my gains some.
1.6 issues I experienced:
Will not hold level especially after yawing, this was everytime.
Tilt jitter
Tilt camera down and gimbal would roll to one side ( about 20 degrees)
level changes from power cycle to power cycle. ( One time level, then another NOT, mostly NOT)
During Actual flight the level rolls to one side and stays even when the take off was level.
During one flight the gimbal freaked out and rolled all the way to one side and the camera tilted down, lost all tilt control from radio, had to land that way.
Next flight after 3 re-sets took off level, then gimbal tilted about 20 degrees and the roll would not sit still
Would not go thru complete set up cycle. roll would only go one way. ( it did ONE time, the first time then stopped)
Lost control of servos to center them... move numbers to Plus + 6000 or Minus -6000 and servo ( tilt) would keep spinning same direction
I did re-install 1.6 many times and all these things stayed the same.
Back on 1.2 and all above issues are gone.
many thanks to photohigher for their prompt suggestions of what to do and acknowledging the issues with 1.6.
( please, don't anyone think this actually happened)
UPDATE!
Tilt jitter
