nicnaimless
Here is where I'm at with my Skyline. If they are looking for Beta testers for the FW I'll volunteer.
Mitypsilon: i know they're at 1.2.2 so possibly your issue is already old (i know this may sound bad but understand it the right way). Whilst waiting for the official release: i'd try manual tuning, it takes really a little to do it.
Vip: as i can't see it named in your post i guess you're going to manage the gimbal with a Skyline board. In that case if you have the fw 1.2.xxx you're ready to set it up as per instructions (manually is better IMO) and go flying, if you have a previous release i'd just wait a few days for the new fw and its instructions. This will save you a lot of time and headaches.
Soaringclauz:
I would really like to do manual tuning! With my software 2.1 it's not possible because there is no button like this. In older versions there is a button but it's not working neither... No reaction of the servos when I change the values.
Does anyone manual tuning with firmware 1.2.1 ? How??
Hello, manual tuning is not button, it is done in the tuning windows by manually changing the values in the tilt, roll and pan servo center boxes. It involves removing belt and mechanical connection of the roll servo and ticking the "servo ON" option in the low left menu. The procedure to do it is in the 1.13 second manual that i believe it's online on the PH site, if you don't find it just send me a pm with a valid mail addresse and i'll forward it to you.
C
Edit: check also my post nr 1215 to see if it can be of any help.
Nice disco, but what has a camera + multi rotor + gimbal + skyline have to do with this? Any HH camera would have done a far more better job than what you are now showing .
So what is your point apart from getting software?
Hi Guys,
Where we are at today:
FW is almost ready. Last week I told you about an issue with the pan, if your landing gear is attached to your gimbal, the Skyline will spin around on the ground. The only solution we could think to this that is elegant is to have another servo input to turn the stabilisation on and off. This would mean that you turn it on once in the air and off when landing. Brendon is coding it in now.
Will post again in a few hours with progress. If all goes well, we can send it to betas (who have panning gimbals) in a few hours, wait for their reply... release tomorrow. Will touch base soon.
Oti
that means official release will be tommorow if i understand it correctly?
Oti
Hi Oti,
I am rying to undersatnd what you are telling us. Means if I have a AV-200 with Landing gear and 360° Pan, I can not use the new FW because my Copter will spinn on the ground ???
My question is then, what is the Pan stabilization then good for ??
Turbowilly
Hi Guys,
Oti
