Photohigher skyline rsgs
Tomvb
Hi photohigher OM,
Im in contact with Sandor from digitech and i will send the skyline back tomorrow.
thanks for the help.
Greets Tom
MultiHexa
Here comes the next level: test flight with Skyline
Here and there it is still shaking.
Let's hope it gets even better with the 1.1.4
Maybe I can still improve on what the settings, let's see.
nisouck
With my skyline monted on a AV130, with pan gain to zero, if I rotate my hexa manually, I can see the roll is moving....
Take a look at the screw at the center; version is 1.1.3.
http://www.youtube.com/watch?v=ipLq5DYR1tw
DennyR
Finally after the change of Tiltservos (Hitech to Savöx), the first test with the skyline.
Here you can see the test:
Roll is OK
Tilt trembles in the movement.
Next step: go flying :nevreness:
If you watch the background you can see quite clearly that any compensation for the actual movement is purely coincidental to the actual disturbance. That is not going to work.
Hello,
i found too that sometimes i loose the horizon. Hope it is something that can be fixed with the next fw. Also i'd like to have the possibility to point the camera upwards. I don't know if 1001copters had success in that but i didn't...whatever i tried i couldn't get it higher than the horizontal.
To Multihexa: IMO the airborne video is good
MultiHexa
@Cédric
again and again:tennis:
You should have a column for the firmware to make in your table.
Just a thought.
traderc
I am trying to play with the tilt center servo but no success.. The tilt servo trembles and goes anticlockwise eventually its compensating. ROLL is perfect !!
Did NYBODY EXPERIENCE TESE ISSUES
Roll is OK
MultiHexa
You can tilt in the software set to reverse.
Gain Tilt postion shall not be set too high, otherwise begins Tilt to shake itself.
More tips I did not.
We will probably have to wait for the new firmware and hope that everything runs clean.
About the gain velocity: it's described in the manual: this is a dampening parameter: the more your push it, the bigger the dampening on camera control will be.
So use it wisely to "remove" vibrations problems.
traderc
Thank-you.... how can I stop anticlockwise rotation on tilt its very little but its happening
I tried centering the servo frequency
Roll seems perfect and dialed in
Is this the firmware or needs some tweaking on the software and what parameter
Maybe this question is answered already but please one more time..thanks
