1001 Copters
Hi traderc
Check that your trim are really on 0
Hello,
We have some problems regarding level position , Servo tilt and roll and working nonstop, 0.4amp consumption nonstop. We get jitter nonstop on the both servo. Both servo are sawox, can check what model if needed. If i push the mount a little up on skyline side then the servos stop making noise for few seconds like they are in middle position and stabilized (as it should be always). How can we fix this since i tried to replace servo with another and same results.
Good morning,
I'm sorry but you are wrong. Digital servo are always making a little noise. The acuracy of such a servo is so important that it never reach the perfect position, so it trys again and again to compensate a liiiiiiiittle in order to reach the perfect position but it can't. That's why it's always buzzing a little.
Hello,
This is not little, this is like if i put my finger on the mount u can see it moove nonstop up and down and left and right for 1 or 3mm. And servo is getting hot since since it is working nonstop. I have done like 100 mounts with piclock and FC and never had this much jitter.
This is above normal, that is why i have wrote the problem.
I understood that you were making the classical misundertsanding about digital servo people usualy doIf i push the mount a little up on skyline side then the servos stop making noise for few seconds like they are in middle position and stabilized (as it should be always)
I really don't know but I'm working on my test bench with win xp and it works fine :/@ Cedric
@ Photohigher
Hi Cedric,
i couldt not resolve the problem with the USB cable. As you know i had send the whole Skyline to Multihexa and he has testet it. Skyline is ok, USB cable is OK. But than i asked him to test the USB cable on a different PC and he got the same results as me. NOT WORKING NO CONNECTION!!!!! Only the message : COM Port OPEN
That means: Tests on 6 differnet PC`s and Laptops and only on one PC the USB cable is working. Also Multihexas USB cable is also only working on 1 PC. All PC`s are using Windows 7.
So, what is the reason for that??????????
Regards
Heinz
So Lanzar, Kopterworx received their batch of Skylines?
