DucktileMedia
Anyone else find it interesting that Drew has not chimed in on here in a LONG time now?
No, not really interesting.:02.47-tranquillity:
Jealous! Wish I could afford the Movi, but it's not in the cards. Hoping the new 32 bit Alexmos can up it's game a bit and get better, ie, closer to the Movi's performance.
Closer, maybe, but the to the best of my knowedge, the Movi, (and the Zenmuse), both use legimate limited angle torquer drive motors, not repurposed brushless hobby motors. A Markedly different technology and *the* choice for serious gimbal systems such as aerospace applications. I keep waiting for someone else to jump on this bandwagon at the high-end of the market but it hasn't happened. I'd buy a Zenmuse in a heartbeat if it would work with non DJI flight controllers. I will probably make do with a 32 bit Alex Mos based system, just like everyone else.
So so worth it if you can make it work for you financially.
If you were to open up the inline box on the SuperX GPS assembly and Google the larger of the internal chips, you'd find that it crosses to a CanBus transceiver Just sayin'
I'm starting to come to the conclusion that the xAircraft on the X8 is not very good. I'm going to wait for another update and see if it gets better. If not, I'll sell the SuperX and start looking for something different. I've two quads and the x8 and don't need another MR. Maybe someday, I can try someone's hex with the SuperX and see if it handles any better. I like flying the SuperX, but I just can't keep it buttery smooth on my X8, especially in the wind. But it does stay airborne!
It's also possible that I don't have it set up as good as it could be, but after hours on the forums and countless hours tuning, I'm guessing that's not the case. Even though I'm new, I've had decent success with other builds so after spending too much time on the X8 w/ SuperX, I'm going to just fly and live with it the way it is till I find something better.
what is the motor/esc combo on this rig?
Just doesnt make much sense that a quad would work but an X8 would not. The motors are at the same cardinal points so what is different other than motors spinning in the opposite directions?
i called Freefly and they said they are swamped with the Movi but are expecting to release the Synapse in late summer.
I was having the same issues with wrapping my head around how the gains worked. Like you, I assumed that the software was "tuning" and the rotary knob was "fine tuning." But as Kloner describes is the more appropriate way to think of it (and how it actually effects the craft).
Also, just a heads up: in trying to figure out all this, Anthony from Xaircraft (very quick responses and helpful) mentioned that Taranis (could be other brands too) often don't equate what superx thinks of as zero and maximum additive/reduction to the atti gain. So for instance on a rotary knob, center might be -6, full left might be -30, full right might be +106. You can adjust this within the Tx with sub-trims to get the throw correct, and that it lines up with what the SuperX wants to see. My Futaba is definitely off, and needs to be calibrated with the aux channel send.
You should be able to check this by powering up and running the gamut on the rotary knob, and then checking it against the G channel section of the log. To make life easier, you can delete the last log you ave in your SuperX when mounted as a hard drive from the log folder - that way the next round of tests will only show your latest flights/take-offs. Makes life easier. And you can rename the file as well for backup (black box will still recognize it).... makes life MUCH easier.
Good luck.
