I was finally successful with my x8/ xAircraft Superx and 2 axis Alexmos gimbal & gh3. I've been fighting gimbal issues that I thought were possibly coming from flight controller, but turned out a 2nd attempt at using ferret rings worked. I've tried them before that didn't fix my problem, but this time put a more windings through the ferret ring and it worked.
I'm flying 3515 Avroto's at around 860mm with 15" tiger clone FC props. I'm around 17.5- 18 lbs with 2 axis / gh3. Will go to 16" with 5d and someday the 3rd axis.
With little wind, I'm very happy with the floating style shots. However, I get an occasional wobble when flying with a little speed. Gonna have some wind the next 2 days so will give it a go and see how it acts. That will be the better test.
For those of you using Alexmos controllers on gh3/ 5d weighted rigs, what are you doing to stabilize (not asking about post fix) your shots at mid to higher speeds? Is it in the dampening for the gimbal or maybe the Alexmos settings, assuming it's not vibrations or twitching form the X8? I tried upping my power on roll, but that introduced some vibration in the gimbal at rest. ( using 5208 iPower 150t motors on the gimbal).
My black box data is showing my vibrations are under .5, 99% of time and motor output is consistent. My prop/engine noise during flying as opposed to drifting seems to not be as smooth sounding as my Hoverfly pro did with 11 inch props and smaller motors, so not sure if that's an issue, since I don't see anything in the blak box vibration graph. The problem is fixable in post, but I'm looking to fix it while flying, just don't know if it's possible.
Since there seems to be a few SuperX users on X8 on this thread, thought this was a good place to get some opinions.
On a side note, I have a small 550mm quad with Pixhawk I'm playing with as well as well as a 650mm quad w/ 3520 KDE motors and Naza V 2. If I get some good results with the Pixhawk, I'm contemplating trying that on the X8 if I can't sort out the x8 issues. I like the x8 configuration, so trying to find a flight controller that will work for video capture. Sure would be nice to get away from stabilizing in post. Also, all 3 of my rigs now have aluminum arms. I'm tired of aligning motors on the round tubes. Have lots of fiber carbon tubes to make gimbals with!
