For a Zenmuse G3/G4/5D/BMPCC/etc. you have direct PWM inputs (each is its own channel) on the gimbal GCU. So you just take a channel from your receiver and feed it directly to the gimbal channel you want to control. With the Futaba 14SG and 7008SB receiver you put the receiver in mode C or D. That lets you send a single S.Bus2 connection to the WKM (channels 1-7) and then you can just connect 9, 10, 11 and 12 to the Zenmuse (9 is on the receiver port #1, 10 is on #2, etc.). This gets you the full 7 channels to the WKM and four to the Zenmuse. If you need a gear channel you are down to 3 on the Zenmuse. To go beyond this you can split the S.Bus on the air side, send one output to the WKM and the other to an S.Bus->PWM decoder. That will get you channels 8-12 as well as the 13-14 digital channels (ideal for gear and two-way switches). It's more work and cost, but you can effectively use all 14 channels if you go this route.
