Please show me how you gentlemen picloc isolated from vibrations
Hi Verid,
https://picasaweb.google.com/116792...hkey=Gv1sRgCKDli9Op8fuxKw#5742810158646085986
Peter
With 360 servis Atv limits works with stick imput, but NOT in compensation,
With no stick imput, moving the gimbal to the mecanical limit and picloc continue to try compensate.
It could be nice to implement this mecanical limit for 360 servos.
Pheliciano You're right with standard servo, but with 360 The atv is servo tab is useless.
Maybe for 360 servo, make kind of atv but in "max angle" like in the slew setup
But for mecanical limits.
Hi George,
A few questions now that I have got the PL v2 pro in hand:
- I have a MK HiSight SLR1, where the roll is coupled to a pushrod. That means that the movement isn't linear. Should I use the exponential Gains -> Roll here ?
- I would like to mount the Picloc on the camera tray itself. I want to do this prevent "qualified guessing" and use the piclocs ability to react to actual changes. But, how do I go about doing that with normal servos ? Also, should I still use the expo on roll in this config?
Hi George.Rene..
Easiest to work with is with potentiometers, and Picloc on Pan Axis.
gm>>
Hi George.
I'm using the AV200, so i go with the "easiest" way.
so far, so good. but the roll is always to slow. its good, but always a little bit to slow. i set up the gains, but when i try different accelerations, it changes nothing. Acc=0, Acc=50, Acc=100. always a bit to slow.
Prop is 275, IMU is on 5, Acc-smoothing=0.
Servo is the Savox 1290MG, which is fast (what i think, trusting the tech.spez.)
what can i do?
Hi all,
Connect to someone Picloc 3X PRO V2 receiver from Futaba R6208SB through via S-BUS Signal Inverter? as this https://www.mikrocontroller.com/index.php?main_page=product_info&cPath=86&products_id=669
and works him ??
Peter
Hello gentlemen, please tell me if anyone has had this problem?
http://www.youtube.com/watch?v=hP-o2mv4CPc
Fly FPV and nearly broke, well I was close by and landed normally: (
Now I'm scared to fly FPV
