Permission is denied
https://vimeo.com/52945565 - this is our reel
Hi all, at the moment im am configuring my picloc3x prov2 -
i started with piclocv1 - and when you place them right - use good servos - and configure them well
they do actually work really good
https://vimeo.com/52945565 - this is our reel (wich is really sad because it wants more hearts- so please press like - if you do)
it was all taken with piclocs stabilizing my mount
hints:
run it on 2s
use fast 360 servos (we use the spectrum h6040)
place it close to turning axes
fix it superfixed... we use its own screws to attach it below cam plate
use a superstiff camplate wich will not bend or vibrate
make the arrow point forwards (where your cam looks at)
i hope that helps! it should.
lucas
hints:
run it on 2s
lucas
Fred's issue was that the Xbee's were series 1, and did not support 115200 baud.
Its good to know that as of now, both Xbee's Series 2 ( and other models that support higher baud ) and also 3DR radios are supported and work.
PaNt. Not ready to reveal yet. But you're on the right track.
gm>>
Fred... there must be a misunderstanding somewhere.... the ProS1 says it supports 250kbps max data.... so it should work !!
