DJI issue,s
Guest
So anyone had this problem?
Esc 1 (M1) will not start (also no ready signs)
works fine on servo tester
i tried swapping ESC no success
i tried connecting M2 to M1 no start also
i tried connecting M1 to port M2 motor will start
all engines programmed correctly all work on RX and servo tester
i dont get ready signal on esc on M1
i swapped MC with otherone same problem
i tried upgrading frmware and downgrading no success
any idea what can be wrong?
im puzzled.. and i have seen a lot
Guest
2 all works fine also in calibration all modes are also fine
Guest
dont get it eather or i must be overl;ooking something .
i can dream any mk setup , swap smd parts , or solve any problem.
and i CANT turn on simple dji setup frustrating :)
Yep BUT does it not spin up in manual?
I have motor 4 on my 450 DJI quad only spins up at the very last second before take off in ATTi or GPS
Guest
well almost breaking my wrist on holding the airframe with a 5S lipo and 2814 attached to them didnt work eather.
3 engines almost fall off exept no 1 wont work
so it does NOT arm as i said...
any esc needs to arm first BEFORE it will work
Pass..
Not had that... what firmware are you on and have you tried doing a reset and starting over?
Guest
Pass..
i upgraded donwgraded believe me , this is the first time i post a message because i am stuck... :)
i tried anything , looked on forums , talked to other vendors.
no idea ..
Have you talked to Geoff at quadcopters.co.uk?
Some times you need to crack one of your world famous beers and sit back and enjoy that then come back to the copter tomorrow.. ;-)
Give Geoff a bell he is a WMK guru!
Guest
i have to deliver over 14 RTF before Xmas , the last thing i can do is drinking my issues away hahaha..
Oh and PS.. that great DW ADX3 I bought from you now has a WMK heart....
Love it even more now..
Guest
NOW I know u been on the Stella as they are all blurred!
Sandor all credit buddy but as I said sometimes its best to just go sleep on it and come back another day... ASK GEOFF!
Since your already thinking it might be a silly/simple mistake are you sure you are in M1 and not in F2 with the ESC plug ?
Set the config to a Octo and test all M1 - M6 ports and the F1 and F2 ports. If one port again M1 is not working than the unit has to be faulty. There is no feature config that would block the output signal of one ESC port !
Guest
good idea will try tomorrow
i did try : new MC no difference
tried : new esc on both mc,s no difference.
BUT : there is signal coming out on M1 its just to high , when i put my digital servo tester in between M1 and the ESC i can lower the signaling towards the esc,
if i then power up the esc does run , but it has to high rpms
