Guest
Stella? thats for marmite drillers
Steady! ;-))Stella? thats for marmite drillers![]()
nah thats really strange why would M1 send out a different signal thus only on that port the ESCs are not compatible. Really set the thing to Octo and check through all Ports with the same ESC. If it works on all just not on M1 than both units most have something. There is no other explanation !
Dave if that happens, then you need to re-calibrate you ESC.Yep BUT does it not spin up in manual?
I have motor 4 on my 450 DJI quad only spins up at the very last second before take off in ATTi or GPS
no esc will work on F1-F2-M1 all others work fine even with different mc,s
the pulse signal is 90 on all ports , i am puzzled here , there is no reason why it does not work.
strangest is if i hook my servo tester between the port and the esc it works fine...
Try to reset the esc and redo throttle calibration. Also try to trim the throttle channel to see if the esc arms.
He already swapped the mc and has the same problem only on certain ports like m1 also tested with same brand but different escs on that port and ESCs that work on the other ports. Strange one !
