nicwilke
wheres the pan?
i dont have pan.
wheres the pan?
I must admit i'm a bit disappointed to learn that PH is abandoning the pot control in favour of the std pwm, skipping the servo response curves was a definite plus IMO but i'll wait for the update and judge by myself hoping i'm wrong.
Nickville: i guess a positive side note about the pwm control is that we'll get fewer cables connecting to the Skyline, is that correct?
I'm sitting here playing with this on the kitchen table wishing it wasn't dark. I'm excited because the gimbal is quicker and smoother than I need now. I think that the Skyline will please most.
Sent from my GT-I9300 using Tapatalk 2
Just tested it and it appears to work fine. Again, rain is preventing me from getting in the air.Hi PhotoHigher,
did you also work on the issue that roll will no be stable when flying sideways or yawing the copter ?
Regards
cropter
In response to an earlier post about mmalik4. Damn! I just bought a Skyline RSGS board from him that I found on the RCGroups.com forum. Hope it works. Looks like he swapped the black and red wire positions on one of the extension cables.
nicwilke - thanks, I just started to make the servo and electrical connections and have called it quits for the night. Just a couple of questions. I'm going to be using this with an AV130 and landing gear from Aerial Media Pros. It seems like there is a lot of messy wiring with this setup on the 130 since the RSGS is on the opposite side of the gimbal compared to the 200 series.
Question #1 - RX. Do I need to use a separate rx for the RSGS or can I plug it into the NAZA on my DJI F550. This will be a solo pilot setup so having to run a separate rx for the gimbal is not high on my list but doable since I have a second TX/RX. I would like to be able to use my main tx so I can control the tilt axis from the knob on my DX7s.
Question #2 - power. It sounds like you want to run separate power to the unit rather than the main flight batteries and from what I've been reading you DO NOT want to go more than 6.5v. I guess that means I can't run it off the NAZA control like I have before adding the RSGS unit.
Thanks,
John
Hi,
Kimberley has posted a new video of the futur firmware to be released (1.2.2)
No more Jitter, pan stabilisation is there and effective
It's seems pretty good don't you think ?
