andre do the blue leds go on when on the Herkules when you have it hooked up to power and have the receiver connected ? By the way do you have a servo tester ?
Boris
Let just say this: you are more help than either Sandor or Andreas.
Yest all 4 blues lights come on and everything looks normal as far as the hardware and getting power is concerned.
The opinions are different though about PPM being present.
About timing and switching frequency i dont know the exact numbers but i did ask for low timing high freq.And the freewheeling on.
Bellow is Andreas's reply and Snador's about the matter;Hello Victor,
didn’t flash Digitech already your firmware in?
It seems that you have not the PPM Firmware on the Boards.
See on my HP how to flash the right firmware.
http://www.andreasbaier.de/index.php/en/herkules-2/herkules2-firmware-a-programming
If you don’t succeed, please contact your distributor for the firmware.
Best regards,
Andreas
well if the blue leds go on it means there is software inside them.
the aknowledge beep is there to show that it is ok , but you must hear also a welcome series of beeps that
aknowledge the presence of ppm signal.
and that is not the casein your case.
so we must sort in what is wrong.
i will try to program another today , and put on a servo signal generator to see if i get the same issue as you have
wil keep you informed
we will sort it out dont worry
Thank you and met vriendelijke groet,  kind regards,  mit freundlichen Grüßen,  distinti saluti,  salutations distinguées, med venlig hilsen,  cordiales saludos,  pozdrawiam,  الاحترام , xie xie nin, zaijian
Sandôr Kruise
And a PS from me.
And as far as programming is concerned i don't quite understand, there is the I2C programming, like giving each motor an adress just like in the MK ESC's programming that it is explained on the Herkules site but no PPM programming which i imagine should to a different thing.
It is the WK-M FC that controls the motors through the M1 to M6 otputs, i am really in the dark here about the programming the Herkules.
Maybe i just dont get it, like the didn't with the MK fine tunning.
Anyway thank you from the heart for trying to help when you have plenty on your own plate to sort out.
I'm far from being at the end of my wits so i'll try to get a OEM cable first and if that fails i may have to try and build my own.
Thank you again for taking so much trouble on my account.
Andrei
