when i started with coaxial quads the conventional wisdom said you had to have alternating props on the top AND alternating props on the bottoms. that means two spinning CW on top and two spinning CCW on top, same on the bottom so you've got four different size/rotation props for a full set of eight. I wanted to simplify that by spinning all of the top one way and all of the bottoms the other. it seemed reasonable to assume that the bottoms would be more prone to damage so I wanted them to spin the conventional way which is (on a plane) clockwise when viewed looking forward from the cockpit. conventional props (tractor as opposed to pushers) are easier to come by and less expensive so if you're going to be breaking props those are the ones you want to break.
i tried this scheme when i built the first test XY8 airframe. it worked great, it survived motor out events, so I've never looked back. THe Mikrokopter mixer table can be configured to run this way, I've got one set up like this that has been flying very reliably for over a year. I just pulled it off the shelf last week and went out to shoot a house with it without doing anything but putting a battery (actually three) on it.
there are a lot of theories but the science behind them is sometimes hard to find. the best thing can be to just build it and see for yourself what it does.
