I'm gonna do a flamewheel hybrid build for you guys so you can see what this things about. the components are
1x TBS Discovery frame w/ core
4x DJI 450 arms
1x naza w/ gps
4x dji 30 opto esc
4x suppo 2810 1000kv motors
4x graupner 9x5
1x lawmate 2.4 1 watt video transmitter
1x pixim 690 camera
1x EzUHF 8ch long range receiver w/ diversity
1x bulk hitec twisted hd servo wire
12x futaba servo wire ends
1x polar pro polarized filter
1x gopro layer lens
1x mictronics digital ppm to analog converter
1x homemade bluebean style rhcp cloverleaf
power connectors, loctite, assorted heatshrinks from 1/16 to 1.5" and servo wire sheathing...
If you already have a f450 or f550 flying all you'd need is the first line item, discovery frame, if you want to transmit video from it, you want the CORE. it's as much as the frame, but makes it all work with as little of interference as possible. My main adhesive used to hold EVERYTHING not bolted down is Welders glue. Lowes has it, true value has it, ace has it. The main property over goo is it never hardens so twisting parts to shear the glue to remove is super simple and then once you get under a corner of the remaining glue, it peels up like a sunburned shoulder peels, super easy. amazing glue. Anyhow, here we go
from austria with love
looking like a party
that's a closeup of the core pre installed in the frame. that powers those solder pads you see to the right of it for cameras 5 or 12v, powers a set of tabs on the other side for the video tx in 5 or 12v and has a video pass through for a basic simple osd that shows current, mah, time flown, and rssi for uhf receivers
Lawmate 1 watt 2.4 video transmitter glued down ready to plug and play to the frame
this is a cross shot showing the pcb for the radio gear. This lessens wires needed to get from the very back keeping the rc rx away from everything else and to get those wires to the flight controller like naza
DJI esc's just rewrapped. i just hate the white, what can i say. usually i do black but this week i got 6 feet of clear so clear it is.
once everything is flown and configured on the core, that piece of tin is a shield that you solder down complete to cover them switching regulators up to minimize the interferrence they make. laser engraved with the tbs logo
build supplies. welders comes in variuous packaging so showed both. the servo ends to clean up the wiring come from servo city. the mic ppm to analog just makes the rssi info feel more comftorable to me. makes it jump around less with false readings=makes kloner braver
this is one really nice camera. securitycam2000 branded seawolf pixim 690 board cam with a 2.8mm lens, think is 120 degree field of view, same as the eye. the cam is bolted to a piece of the frame that comes with the kit.
got shrink wrap? I got drawers of the stuff, got it hanging from the wall. i gotta be the only hobby guy that buys hundreds of dolars of shrink wrap at a time. frigin knucklehead
4x DJI 450 arms
1x naza w/ gps
4x dji 30 opto esc
4x graupner 9x5
1x pixim 690 camera
1x gopro layer lens
_795.jpg)
.jpg&s=795&q=85&wmk=!)
