Hi guys,
Well after doing a bunch of research and asking some questions I came to the conclusion that my X Aircraft woes with my Octo were largely due to ESC settings, so I went from a PWM of 8 to 12, which is the highest setting in the Hobbywing 60a Platinum ESC.  I also went from 0 timing to 22.5 degrees and those two changes made a world of difference.  Looking at my flight logs my normal prop average power use for a one minute flight just hovering in no wind is roughly 55% for those four motors and the pusher motors are right at 60%.  I made an aluminum tool to bolt to the motors then using a four foot long metal ruler I aligned each motor as precisely as possible yet I still have this difference.
I was unable to get the yaw stability anywhere near as stable as my Wookong machine, but in all fairness that machine has the normal motors leaning left at 3 degrees and the pusher motors leaning right at 3 degrees.  So I went back and revamped my motor alignment tool for a three degree tilt and readjusted the motors on the X Aircraft machine to the same 3 degrees of tilt and Bingo.  Now my X Aircraft machine is flying really well in the wind and it will be put into active duty.  I still have some tweaking to do on the gains once I mount the camera mount to the machine.  I have had the mount on the machine before and the video was great, but you could not fly the machine in windy weather.  Right now it is at 1.0 on the altitude gain, 1.7 on fore and aft and right and left and 124% positive gain on the external for GPS stationary hover stuff and 70% for attitude mode when cruising around.
Thanks for the help with the questions I had Kloner and everyone else and if the rest of my flight tests go as expected my Wookong controller will be taking an early retirement in the next few weeks, without a benefits package I might add.
I was going to edit my other posts in this thread, but it won't allow me to edit the posts.
Wayne Mann
