Question time - I have the rsgs fitted and working but I cannot set a roll limit.
I have it set 25/25 deg but it will roll as far as the copter can go. When I flipped the hexa the other night, the mount tried to keep up and made coffee grinder noises... not good!
So - it is set in the software to 25/25 (and saved).
Pete
This is one of the bugs already reported to PH and still unsolved. Limits work only as a limit to the travel you can do with the radio. Compensation can override them and do any damage that servo power, current and attitude allow.
Oh great... thanks. I'll to flip less![]()
Setup the compensation switch and disable the compensation when you flip or crash
Be careful, if you move the camera when the switch is off, when you switch on it will do all the previous movements at full speed, another problem to fix in the software
Anyone using PAN compensation? How can I setup it when the PAN cable is used by the PC software?!
Is the Aux connection supposed to do anything currently? I hooked it up to the gear channel and I can use it to turn off the stabilization but then it won't turn back on. My landing gear is attached to my gimbal so I would like to be able to turn the pan off until I take off to keep it from spinning on the ground.
Raw video without selective editing I hope :apathy:
