Hello!
I am trying to setup my av200 with skyline, and i followed the instructions, but when after I set level x&y, and Z, i save, and press autotune, the z axis (pan) starts spinning over 360 degrees, yanking out the cables attaced to the av200...
What can it be?
I have removed both pots as the manual said, I did save after leveling the x&y and z, and I have the new harness with the dummy pots... (there is a cable out of the skyline that sais "tilt pot" I think, but that isn't connected to anything...)
-Kjetil
How are you guys powering your Skyline and the servos?
What is the Roll pot for?
Yeah mate,Sooooo the way I see the physical connection is correct?
Pete
Thanks guys.. I am using a CC Pro Bec also but I also have the new High power Spektum extension module so was thinking of supping that via the CC Bec and then supply via skyline the servos...
OR
Would you just supply the servos direct from the CC bec.. Guess I am aining this at you Ken ;-)
