Over the weekend I finished building my MK FPV quad, replacing the Hoverfly Pro board that was most recently on that frame. Once I got it in the air and everything dialed in I swapped to the latest and greatest firmware to see what the difference is between the .82 version I've been using and .88. I was very surprised at how solid this latest release is, it's almost like flying a WKM, altitude hold is light years better than before and position hold is pretty solid as well.
It worked so well on the quad I made a leap of faith and upgraded my trusty Hexa V1, now with Droidworx landing gear and newly reworked AV 130. A while ago I was out in the front yard test flying the Hexa in 12 to 15 mph winds and it worked amazingly well, held altitude as good or better than either of my WKM in the wind and position hold held up fairly well too. The little Hexa doesn't weigh much and with the added loading of the AV130 the stock Roxxy motors were working overtime to keep it on station in both vertical and horizontal planes. Looking at the video afterwards I was amazed at how steady it is considering how bumpy the flight looked from the ground.
Holger has a winner with this release, I think the competition from DJI has lit a fire under MK firmware development, this is the best release in quite some time and the improvement is very noticeable. I think I may take the Naza off my Droidworx AD6 and put the MK stack back on to see how well .88 works on larger and heavier setups since it works so well on standard MK setups, the true test is how it holds up on non-standard builds.
