Hello!
I have been reading this thread with great delight!
I have been flying my mCPX for a while now using a DX8. I had a Blade 450 3D and hated it, so I eBay'd it. I had plans on building a TREX 550E DFC, but this hexacopter thing bit me in the butt! I don't have a lot of time right now to head down to the field and work with the local boys in the club to get a 550E with the BeastX going. So in the meantime, I wanted to be different and go the hexacopter route since I believe that I will stand a better chance of getting this thing built and in the air on my own. In January, when I have more time, I'll go the TREX route.
Anyway, I have one the way, a DJI F550 with the Wookong-M and the basic 550 landing gear. I can't wait to get it! I so appreciate the tips on soldering as it has been a while. So I broke out the old Weller 40W (WLC-100) and installed the chisel point. Tinned it; and twisted 2 wires together to see if I remembered how to solder. I had to keep the knob at position 3 - position 5 seemed way too hot! I successfully soldered two wires together. :nevreness: I bought flux from Radio Shack, but I'm not sure I will use it when soldering connections to the lower board (suggestions?)
Also, I'm curious which gauge wire to use to make the power lead cable from the bottom board? Also, what kind of connector do I use for that? I have never soldered a connector on to a battery before either. Is there anything to be careful about? I know, I shouldn't short the leads! But I'm not sure if there are any hidden caveats that I'm unaware of. Also, I'm not sure what size battery to use as well.
Thanks in advance for the responses!
I was more thinking of videoing it on your mobile phone or something, to show what it looks like from your perspective..
I know exactly what you mean, once you plug that lipo in, the clock's running and who wants to waste any precious time!?
Hello mmurfitt;- Get a good soldering iron, the solder kit I had was good (bought especially for the job) but the 'iron' part was rubbish, or rather the tip of the iron was rubbish, I got a new 'tip' and it transformed its effectiveness. What took me hours to solder should have taken minutes.
If you're not used to soldering, or don't have much experience then practice. It's not too hard to solder, but it does take a bit of practice to ensure it's not too messy. There's plenty of YouTube videos on good soldering technique, I found this helpful:http://so.ee/nRd
Hal, I'd try just reheating the blobs. They should reshape into a nice round ball. And I used my weller on 5 for the entire project, and once again, make sure your tip clean as a whistle.
What made you go with the 10x5"s? I'm getting a recommendation of using the 8x5"'s. Any issues with the 10's? Your thoughts?10 x 5's.
mmurfitt....can you post a pic of your 550? Wanna see what ya got and where... I agree on the instuction manuals, or lack thereof!! I feel like most of my build instructions has come off of youtube, and I don't think we should have to spend hours trolling the videos looking for how to do something. Got my Graupner props yesterday. Checked a couple for balance and they were right on. Checked one of my old DJI props and it was way out of balance. So maybe that affected my little wobble I mentioned in previous posts.
Back to FPV...did you go 5.8? Straight antennae or the circular? Separate battery to run video? Did I hear the GoPro video feed is a bit delayed getting back to you? I'm looking at FPV equipment now. Wish I could find an all-in-one purchase that I could just hook up and go...already have my eyes set on an Octocopter with a good video camera for the spring....can't get this one up and running fast enough.
Thanks.
Thanks.
