Looks like no purchase for today. Refund hasn't come back in, so the $$ will be tied up until I get the refund from UAV Products. Praying I can find another f550 kit thats actually in stock by the time my refund is fulfilled. Frustrating, but everything happens for a reason
@motopreserve, yes the crane gimbal is a servo gimbal and while they are out of vogue, it does provide a few benefits as a starter gimbal.
First it was relatively inexpensive when I bought it used over a year and a half ago. Second, it's fairly light and doesn't need a separate control board. This was important since overall weight of the rig is a concern. Third, it can fit a gopro or my Sony nex and attach and balance easily on the f550 frame.
May have to look into that for a gimbal that supports my GoPro and lumix .
Still no refund from UAV products, now playing the waiting game while my $$ is up in the air. Bummer, will keep checking!
That's great to know Jay. I had just mentioned that I didn't know of a gimbal that could handle both cameras. But it makes sense that a servo might be able to handle the difference in weight. Although I've read the posts, I have never been one of the people to trash-talk the servo gimbals out of hand. The only drawback I can see now is that the entire industry steam-rolled past that technology so quick that they've probably stopped innovating in that area.
How does it handle it when you swap cameras? Do you have to adjust for it in the FC software? I'm assuming you run DJI FC?
thanks!
Chipwich,
Do you have any experience with brushless gimbals that can accommodate a Sony Nex size camera? Are there any that might be a direct plug into the Naza or would I need a separate controller? I'm controlling the pan/tilt of the camera from my rx but want roll to be handled by a controller.
Got the ARF f550 kit! Hyped
-f550 frame
-30A ESC's
-2212 Motors
-10" props
Do I need any additional wiring or connectors to solder this kit together? Never soldered before, just want to make sure I have everything needed on the first purchase
Ordered a 4s LiPo to connect. Thanks for the gimbal info also, purchasing one tomorrow!
Your bottom plate serves as the PDB, so you won't need anything extra. Search for the Aerial Media Pros F550 build video. It's a couple of years old, but the best one that I've seen. I would suggest soldering a couple of JST male pigtails to connect FPV, a brushless gimbal, or LEDs. I ended up taking mine apart and soldering the LED leads for each arm right where the respective ESCs connect to the PDB, but you could just solder one JST and connect a LED harness. It depends on how you like your toast. LEDs are optional, but they really help with orientation, especially for new pilots.
Good luck and post any build questions.
PS: Jaybeast is correct. You should run 8" props with a 4S lipo. It will feel sluggish with the 10" props with a 4S. They are cheap and you will be breaking them on a regular basis. That's good, because rather the plastic props break than something expensive They should be hand tight only, and whatever you do, don't use threadlock on plastic parts, including props. The threadlock degrades the plastic turning them into missles :O
I think all the batteries from RMRC come with deans. They will look brown/maroon in the photo. It should say it in the battery info.
If the f550 comes with that - stick with the same. Most people steered me early on toward XT-60, but there are countless Deans fans out there - so you should be all set, and not resold wrong battery leads w
having never soldered might be your best bet
the taranis sold out???
