Ryan there is not real need. At the same time the dampeners are there and don't weigh a lot so why not use them for that ! On the other side yes every component will be happy to be isolated from vibrations.
Sorry haven't answered you PM yet will get to it tonite
Fair enough, it cant hurt by isolating them. If you didn't have the cs dampners, would you go to the trouble of adding dampeners to the board?
Thanks for that.
Okay started with the placement of the WKM components and installing the Herks with the ribon cable and the micro match to servo plug converter.
Since the herks are placed under the center plate the ribbon cables are a bit long. I shielded them with cat 7 foil. Micromatch plug in the herks
are hot glued in case some vibs hit the boards and cause the micro match plugs to loosen. Elkos like said fixated with silicon.
Hmm parts are dirty think time for a cleaning session.
If i finally had my parts i could start placing the RX and the LED and give it a test flight hmm but still have to wait.
krleas, I am a little worried out the center plates of the CS8 to take extra loads and yes I want to do payload test up to 12 kg full setup. Should I have any worries like support the center plates ?
krleas
FPV Freak
Boris for heavy lifting CS we always use 2 bottom plates. So 1 on top and 2 on bottom.
dammit i have to desolder everything again ;( better be safe whatever.
At least the material for the made parts arrived :) This 6mm carbon plate is massive ! :)
:) close to a spaceship I guess :) No only for the holders on the side the adapters for the s800 landdingear and Zenmuse.
I made a big mistaken and told my nieces to give the bird a name. Now its called flower ;(
krleas
FPV Freak
hahaha Flower the 12kg heavy lifter.
think this really speaks for itself ! Nice one guys:
elossam
Very impresive numbers. They are just halve I got with the same engines, load and airscrews but with 6S vs 8S. In watt therms there difference is way high.
mk-Thor
2 new Videos avaible:
https://vimeo.com/54977756 Herkules III 8S vs. 24,9kg (DJI Wookong, Axi 4120/20)
https://vimeo.com/55182862 Herkules III 6S vs. 8S (DJI Wookong,Axi 4120/20, 13,4kg lift off)
- Oktokopter Frame AS8, 118cm dimension between axes
- FlightControl DJI Wookong (powered by 8V Herkules BEC)
- Motor Axi 4120/20 465kV 37A
- Props 14x8 Graupner E-Props
- ESC "Herkules III" 8S High Voltage Edition with active freewheeling and PPM Firmware (i2c Firmware for Mikrokopter also avaible)
1. Flight:
- 6S/8.400 Lipo (2x 6S/4200)
- 12,8kg lift-off weight (Kopter 5,6 – Lipo 1,7 – payload 5,5)
Hover Amps = 75A (Hover Throttle balance not good on 75% Throttle Stick)
Max. Peak = 156A
Air Temp = 1°
ESC Temp = 2°
2. Flight:
- 8S/10.000 Lipo (4x 4S/5000)
- 13,4kg lift-off weight (Kopter 5,6 – Lipo 2,3 – payload 5,5)
Hover Amps = 60A (Hover Throttle balance very good on 50% Throttle Stick)
Max. Peak = 252A
Air Temp = 1°
ESC Temp = 3°
Vortex
https://vimeo.com/55182862 Herkules III 6S vs. 8S (DJI Wookong,Axi 4120/20, 13,4kg lift off) (still uploading)
1. Flight:
Max. Peak = 156A
Air Temp = 1°
ESC Temp = 2°
2. Flight:
Max. Peak = 252A
Air Temp = 1°
ESC Temp = 3°
Thanks for sharing your findings. Were you using the same props for both tests??
Regards,
Lance
