I didn't bother to buy the sensors I use a DJI Mini OSD instead it has it's own current sensor.
It makes sense once you've done it. Basically, with the old method you accessed the radio and SD card with the radio running (firmware booted). Now you enter another program (Bootloader) to access it without the radio booted. You hold the aeleron and rudder trims inward and power it up. Now plug in your USB cable and you will see it in Windows Explorer like it is a USB storage device attached (hence not needing drivers). I've got an old iMac at home and going to try that tonight just to see if OS X can recognize it, which woulld make the Mac folks happy. Trims are not effected because you are only getting to the Bootloader.
Thanks, Scott. I suppose I would need two of them. I have use two batteries in parallel but they attach at two different points on the PDB so that if one connection fails, I still have one good connection with hopefully enough current left to land the craft. So I wonder if there is a way to connect two of those sensors. Even if there isn't, one is better than none if you find that it is fairly accurate.
So i've been sucked into this Taranis hype, and seeing how it's sold out everywhere.
Would Taranis be a great tx cost-wise if my main intention is FPV with goggles? Seems like I'd be getting a OSD to display data in the goggles so I wouldn't be staring at my tx for telemetry data...
Or is there an "ideal" tx for FPV with goggles?
I'm not sure if one Tx is better than any other for FPV specifically. Keep in mind that you don't have to buy the sensors for the Taranis - they are an add-on when/if you want them. But remember that OSD may track voltage, but may not track mah used/consumption (which I find more valuable). They also may not track individual cells of the battery - so you can be aware of the lowest cell instead of just the total voltage. Just depends on the OSD you'll have and your needs.
Without any telemetry, I still think the Taranis is the most customizable, bang-for-buck Tx available out of the box. The ability to get into a computer based GUI and edit is priceless. And even with OSD I appreciate the telemetry because it's easier for me to hear the data that scan the screen when I'm busy learning to fly FPV
also, I think that there will certainly be times when FPV is not appropriate - and then I'm sure I'll be glad I have the telemetry.
While certainly an OSD reduces the need for full telemetry via your TX, I find is that it is almost impossible find one that shows you all of the info that you might want. So, a radio with audible telemetry call outs, like "RSSI Critical" that the Taranis does when used with a FrSky RX, perfectly complements an OSD, especially if the OSD is not pulling info from the RX and you might be using one of those "illegal" sets of FPV goggles.![]()
Aside from chipwich himself claiming the FPV goggles are illegal, much like the FAA, without any legislation,better make sure you practice flight LOS first right?
When you do a little more research into the Taranis you'll realize that it can start your coffee maker, pour your first cup, and drive you to the flying field if set up correctly![]()
That's what my little Syma X1 is for
Won't be flying FPV right away, probably going to put in a few dozen flights before I even think about doing that. Dont wanna get too far -- still worried about Naza flyaways .....
The FAA said they're going to start working with local law enforcement and educating them on the illegality of FPV and flying outside of LOS. And Amazon making such big headline about their Prime Air certainly isn't keeping the FAA's attention away from this hobby....
Edit:
Btw, are the aluminum carrying cases helpful at all? Do you guys actually use it to carry your tx to the flying field?
