This is completely embarrassing and should provide a great laugh for all of you...
After all of these attempts at esc throttle calibration I was narrowing it down to the possibility that the numbers were wrong on my esc wires. I put numbers on all of them when I ran the wires. So my thought was that I would wire up a different esc/motor than #1 and see if I was able to get the proper calibration beeps.
I also put stickers on the top of the arms as a reminder, though I do know that motor #1 on a hex is the front right, then they proceed counter clockwise.
I saw the #1 on the front LEFT arm, not the front right. It was at that point that I realized I may be the biggest bonehead in the universe. I was trying to throttle calibrate the front right motor, yes, but the f&*!ing bird was upside down! That meant that the front right arm was #2, not #1!!!
What a bonehead!
Go ahead, let me have it. I deserve all the grief you want to dish out.
I proceeded to throttle cal 5 of the 6 motors. Motor #3 does not respond. It does the constant beeping to indicate no throttle connection. It appears that ESC #3 has a bad wiring job or perhaps a short. I'll be getting the multi-meter out to test all the leads first. If I have a short or the wiring is bad, I'll have to pull the ESC wires through the arm, fix them, and re fish it. That's a total PITA. The good news is though, that arm #3 is the stationary arm and has an open end. Fishing it may be slightly easier than the folding arms of the T960.
Humbly yours...
