TBS Discovery Pro
epic4me
Kloner, what gains are you using on those arms?
Does the length does not induce a resonance in the structure? Since the longer the arm, the more noticeable the "momentum" on the motor propeller, what do you suggest on battery, motor and propeller ?
my gains are the same no matter the arms, motors, usually 140-140-120-130 and anywhere between 80-80 and 100-100....... where ever self leveling interaction and i quit knocking heads.
Never seen any resonance, only thing i've witnessed is it can be over propped... at which point becomes extremely unstable
Theres two sweet spots i've hit so far but were bringing in some u series tigers to check through those. the tiger/amp 3515 500kv on 12" without load, 13-14" with load and the standard length arm kit with 2814 and 900-1000kv on 9-10" props..... with the 900-1000kv we run the zippy compact 4s 5000mah packs, on the 3515 we run the zippy compact 6s 2700 mah.....
U5 look promissing, bigger better bearings, more power than 3520 but alot more efficient
These arm kits with the big motors/props have an unbelievable amount of yaw authority if that's what your asking, guessing that's the momentum ?
epic4me
Thanks kloner, Inspired in you project, I made some inserts ( not very good looking ) for the arms using 16 mm carbon tube and a tarot motor mount, and 3520 with 6s battery at 5000 mAh, the total length of the arm is 36 cms, the quad fly more than 26 mins but there is some yaw; I expect you have your kit soon for sale been waiting since I saw the kit )
View attachment 15145View attachment 15146View attachment 15147
Is there a way to correct that yaw?
I used 16" 4.5 prop
Then 14" gemfan and got better
that is the default gains from the latest naza settings. 125-125-100-100 and 125-125
Boltzman
Packing up my Klonerarms TBS NEX-5 Disco for a 3 weeks flying trip in the Philippines. Everything incl fpv equipment etc fits in a backpack. I will bring a full dual redudancy setup so I can go some extreme with flying. Waterbuoys, triple gps systems and gps trackers are set to recover from the most distant crashes. Keep you updated how the Klonerarms and GotheliRC VX5 gimbal delivers in these extreme conditions.
epic, those are 13"
Boltz, good luck my man. We will have a few production kits around the 24th, if you get in trouble let me know, i'll make it happen
Boltzman
For now only a micro dvr recorder to record the gps position data for later recovery. I have one naza gps, osd gps and robbe/futaba telemetry gps.
Boltzman
Been flying the Klonerarms and GotheliRC VX5 gimbal here in El Nido, Phlilippines. Extreme heat and wind! They stand up pretty good. Videos to come later.
tstrike
pendejo grande
Steve did you ever figure out the 22mm arms or just stuck to perfecting the 16mm? I finally got a used nex and was thinking about a y6 but after seeing Boltzman's disco, I may blow the dust off your old frame and go this route.
they are 16mm, and they come with the kits. there should be a press release shortly, i gotta get up there this week to take care of other biz and will push towards getting the release out.... 4 arms with everything you need for up to 14" props, cut down the tubes if you want it shorter. Just replacing with these running stock length and 2814 with a nice prop is amazing, but you bump it up to a 6s 400-500 kv 3520-3515 it's off the hook. boner material
JG-rn
what kind of flight time with the 6s and 3500kv? 14" props?
