RyanMcCrae
Hi Rob, Images have been sent
Hi Rob, Images have been sent![]()
Nic big rig. What will you lift with it, other than small children or pets?
Looking good, how much was the AUW?
I have sent you the relevant images from my system. I am sure when you make the changes it will work.
Cheers
Rob
Rob
I'm in communication with Peter at Zero - re trying to make my Google Nexus 7 tablet connect directly to the YS-X6 mini Wifi unit - but not sure what he's trying to tell me ...
He says when the mini Wifi unit flashes a blue led only - this means 'external router mode' only is available. The mini Wifi unit has to be flashing a red led to allow direct phone/pad communication?
Problem is, I can't seem to configure the mini Wifi unit to flash red led - only blue?
The software 'SeanyConfig.exe' runs ok (I am using Windows 7 - 64bit) - the Com Port opens ok - then I press 'Apply' button and nothing happens. Nothing happens for 'AP' or 'Infra station' mode.
I have tried plugging in prolific serial lead into YS-X6 Mini Wifi unit using both ways (ie. black wire towards outside of unit AND black wire towards middle of unit - same nothing result).
I can access the YS-X6 Mini Wifi using my big TP-LINK router by entering 192.168.1.254 - wifimodII - but I do not know which settings to change - or if I can use this method to set 'PTP' or 'Router' mode?
I have checked on many forums but can not find a solution.
Do I have an older Zero mini Wifi unit that just doesn't offer direct phone/tablet connection?
Any thoughts would be appreciated ....
cheers, Dale
Is this happening also when setting mode is active? This is totally normal if you are in any flight mode with altitude hold, motors will spool up and settle when throttle is over 50% and copter is in the air.
