Zero UAV Zero UAV YS-X6 [Owners Thread] *Autopilot system for multirotors*
nicwilke
All up simple.
Efliernz
Pete
Looks too simple!
I look fwd to seeing the features. As I said, waypoints are not a biggee for me but a solid position-hold would be great so I could solo shoot. Not fussed about RTH etc, I like to fly / be in control ;)
Pete
nicwilke
Heres the specs on the low end model: YS-X4 Bluetooth model.
1 Auto (Takeoff/ Go Home/Landing)
2 Target Lock & Fly encircle
3 Fly to Pointed Place (No more point within 20 seconds+ Distance up to 30 meters between points)
4 Realtime Flight status (Google Earth Map)
5 Auto-Navigation(4-waypoint + 200m diameter)
6 Fail/Safe (Auto Hover--Go home--Landing)
7 Low Voltage Alert (By Phone Vibration)
8 Built-in Gimbal Stabilization
9 Flight Control Mode(GPS Atittude Mode/ Atittude Mode/ Manual Mode)
10 Bluetooth Module Supported
11 Bulit-in Damper Module
12 Optional S-BUS/Ordinary/Self-Adapted Receiver
Pete, I think this is definitely what you're waiting for.
Efliernz
Pete
Thanks Nick... it does look good.
So want doesn't it do compared to the X6 is probably the best way to ask? Just trying to get my (shift-work tired) head around the options. I didn't know they existed until last week ;)
Pete
nicwilke
Pete
Well thats a great question, as Its more than what I use my X6 for. I think the features are barred a little, ie: limited distance on click and go stuff, and waypoints, but as for other stuff, I'm not sure what the X6 has over the X4 (other than octo + gimbal stabilizer which is pus anyway). Small, would fit in the XM-6 so much better.
nicwilke
The YS-X6 will get an upgrade in its firmware (and perhaps hardware) to be more pro. More features with GPS, telemetry etc. The X4 will be a NAZA slaughterer. This is a great unit for around $500
johnno
Hi Nic, thanks for that how do you think it would stack up against an XAircraft setup?
Efliernz
Pete
Nick - I presume from your "(other than octo + gimbal stabilizer which is pus anyway)" comment, the gimbal control is crap! Are you using a separate gimbal controller?
Pete
nicwilke
slow upload it is
any idea where in US i can price a X-4? as in dealer over here.
Mongo, I've been told the price is not set yet but about $600 entry (bluetooth connectivity model) upwards to $750+. Theres 3 models.
Kari
Price and x4 will be published today in few hours..
Edit: few hours means few days i guess.
robone
Are there any hotspot apps for android, that would allow me to set IP, SSID and pw, to connect without a router?
edit: If that's not possible, will this router work?
http://www.tp-link.com/en/products/details/?model=TL-WR941ND
Any Android tablet should allow you to set up a hotspot. The software comes with the system.
But it is better to get the router as you will have better range. That is exactly the same router that I have used.
Rob
vispaaja
Rob
I tried to use the hotspot function; set the SSID and password and even got the blue light to lit on the WLAN module, but the phone isn't receiving any data. Probably because the hotspot doesn't allow me to set the IP adress. I'm using a Galaxy S i9000.
Anywayz, I ordered the router, hopefully it will make things easier :)
