I couldn't cut together a good video to save myself, but I do have a grasp on how to obtain the aerial footage.
...they must have known that was what and how they were going to shoot it before they ever turned on a camera.
I mounted my gimbal on the same handle you used to mount the MobiGo, I got it at some trade show for about $20. It works pretty well but no matter how hard I try you can still see the "walking bounce" in the footage.
Its easy to turn this thread into a discussion about hardware, rather than technique, but wouldn't it be great if there was a small GoPro/NEX gimbal that you could mount on a handle that could be easily disconnected and mounted on a MR in a couple of minutes without having to re-balance or tune it. There seems to be a ton of people trying to build BG's but I haven't really seen too many that might work for this sort of application. 90% of the time I'd use it for handheld shots.
Which gimbal did you get for your NEX? I'd sure like to be able to buy a BG for my NEX that was small, similar to the one in your video and plug-n-play. I'm so tired of having to continually "tune" flight controllers and gimbal controllers.
Paul, which gimbal did you get for your NEX5? Also, how well do you like the Quaternium gimbal. I think the Hero 3+ might be a better AP camera than the NEX5 especially since it shoots 2.7K @ 48 FPS. I like 1080 @ 60 FPS but its too slow when you use it in a 24 FPS timeline.
It appears that the low light performance is improved as well so it might also make a good walking around on a gimbal type of setup.
Stacky, what do you have to change when you remove it from the hand-held handle and invert it to hang it below your MR?
Also where did you get them and for how much?
Chuck, I've been using the 3+ for a few days now and just put it into ultra wide 1080 48fps for the first time. Wow! Obviously there is going to be distortion at the edges but the horizon stays surprisingly straight and the clarity and largess view put that setting in a class by itself for that size camera. I also use the camera for fpv so it helps in that department as well. There is a a thread in the AV section that is saying the 3+ is a little softer than the BE at distances approaching infinity because GoPro designed it that way. They propose a fix of loosening the lens and twisting until infinity is sharp again. I haven't looked at my video that closely yet to verify and don't plan on touching the lens. It's also lighter than the BE so I've taken advantage of that and started flying with the GoPro case on (sans back cover and mounting hardware).
You can at least do something about that. This is an excellent tutorial for those who want to risk loosing the hitherto ambiguous warrantee that GoPro offers. This camera now becomes a serious contenderPoor QC![]()
