gave me the sticker work,,,,
http://www.secure.waterfowldecals.com/index.php?main_page=product_info&cPath=71&products_id=435
Kloner,
Is that the red large that features on your case ??
Kloner,
no it isn't, that was a 9" 2 color. if you buy a medium one color i'll make you that 9" 2 color for that price, just add to teh notes when you check out or reply to your receipt so i can make the note. i'm cutting everything everybody ordered now. You guys are the best.
Did you get that exact case? it has a space 10" wide to put it
that's what you see on my case and that's the outter square 11" , 9.5" sticker. can make em any size
I'm not sure if my sites gonna be Aussie friendly, we might need to do this with paypal. i know it won't do cananda and i've worked and worked on it to do it..... it's all enabled, just doesn't like my usps module, can't correct the address or some crap so it times out
the current sensor is in the frame...... no others needed
have fun, let us know if you hit any snags. if you got the arms from trappy, be careful with them bolts he sends out. They round out easy, other than that totaly solid kit
volts is the flight pack,,,,,, the 100% is the rssi signal strength from the ezuhf. Any receiver with rssi can use it, or you can disable any of it but volts. all the long range systems use rssi...... receiver signal strength input i think
They have external rssi meters for video if you wanted, it'd go on the receiver end, but it's not needed, that's what static is
these are the water buoys. i run one on the bottom. it's a co2 cartridge that inflates a balloon if it goes in water
