Had a great day FPV-ing yesterday at the field, got roughly 1 1/2 hours total flight time between my DJI F330, F450 and Mk quad. With the MK quad I was able to set a personal best for distance at almost 2000 feet out, OSD reported around 1940 from takeoff point. I was a bit surprised to find perfectly fine video and no loss of TX signal at that distance using just a standard JR 11X with dual satellite RXs through a diversity board on the MK and the Immersion 600mW 5.8 VTX with IBCrazy cloverleaf and a SPW on an Uno RX at the ground station and the same antenna on the Fatshark Dominators. I got out to around 1750 feet with the F330 and probably could have equalled the distance of the MK but going that far actually leaves the boundary of the property and puts the multi over a residential area along a well traveled road so I kept the rest of the flights within the limits of the field.
The recording was done at the ground station using an FPV-Japan DVR, the flying was done using the independant VRX in the Fatshark Dominator goggles. I was slightly surprised to see the video recorded at the GS was in some cases better than what I was getting with the goggles. I think it may have to do with the SPW antenna being so close to the goggles (and my head) and the antennas on both the F330 and at the GS on a 30cm mast which certainly helps avoid multipathing.
Anyway, heres one of the flights with the F330 going out to around 1700 feet, where I turned back you see some static, both times I was a little too low and that put the antennas behind two dirt hills and a line of trees about half way out. Applying a bit of throttle to gain some altitude and clear the obstacles got a good clean signal back, on other flights I kept the altitude a little higher and had less of an issue with static at extreme range, 5.8 really is LOS...
I just ordered a tiny OSD for the F330, if it really is as small and light as it appears in the pictures I think I can squeeze it into the minimal space left on the 330 frame, it would be nice to see battery voltage, distance and altitude while flying.
