helloman1976
Ziptie Relocation Expert
Check these out, this is from yesterday from Amelia Island and Little Talbot Island.
Today was a bit warmer than its been here lately and the wind had died down to 6 to 8 mph, a gentle breeze compared to some of the steady 20+ mph that's been blowing through recently. I really didn't plan to go flying today but seeing the clear sky and light wind got me out the door with the Discos and my newly constructed F330 FPV...
First time out for the 330 and it definitely needs some fine tuning before it's 100% ready to go. Got two flights in, the second cut short by the GoPro coming off the front end and since I was using it as the pilot cam the flight ended in the snow soon after. Also got a couple test flights on Discovery #1 now powered by a Quadrino Multiwii board, also needing some fine tuning. My go-to Discovery #2 was up for some stick time though and I got a few good flights in before the wind picked up to the point I had to pack it up, well that and the fact on the last flight a gust of wind knocked the ground station tripod over and in the process yanked the goggles down over my nose resulting in the ending you see in this video. With the Disco now well packed with snow between the frame plates it was time to put the gear away and head for home to dry things out, still a great morning of winter FPV flying...
they have to be to correct for magnetic north. You fly forward in gps mode and watch it's path, twist to correct the path and repeat or you can just look up your exact corrective amount for your area. mines like 16 degrees off here in SD
Why aren't your gps pointed exactly forward? They're both crooked.
Couple questions, what did you use for the legs that the 330? is sitting up on? Also, are those APC props on the disco? Last question, the CP antenna on the tranmitter on the 330?...what frequency transmitter is that? 1.3Ghz CP antenna? Thanks!
The legs are 3mm carbon fiber tube with a solid carbon fiber rod superglued inside and heatshrink tubing over the outside. Each one is held on with three tywraps which usually just pop off on crash landings leaving the leg intact and ready to be tied back on. The colored shrink wrap makes them easier to find in grass, dirt, whatever, when they do come off. They've proven to be very durable and I haven't had one break yet even when the arm it was attached to wound up in two or more pieces...
The Disco is currently flying on APC 9 x 6 thin electric props. I find the Graupners are a bit too brittle in sub freezing weather, I've had three break in the last week from just tip overs on frozen ground on other quads and given they cost about 2 to 3 X what APC do it hurts the wallet less to break the APC rather than the Graupners. In warmer weather I've used both 8 x 5 and 9 x 5 Graupners on the Disco, it has a little more speed with the APC and they don't seem to affect the stability at all so I'll probably just leave them on.
In that pic the 330 has an Immersion 2.4gHz video TX with a RHCP antenna I made and the RX hiding in the back is an Immersion EZUHF 433 mHz 8 channel. I have since replaced both the video TX and the RX as the RX started acting up, the 330 is now on 5.8/2.4 again until I get to the bottom of whatever is ailing the UHF RX. It may be a bad RX as I swapped it over to my other Disco that has a Quadrino flight controller and it's glitchy on that as well. A 1.3 CP video antenna on the 330 would look huge on that small frame but I'm thinking of trying it anyway as soon as the notch filter arrives so I can use one of my 1280 vTX with my 2.4 radio gear.
