I am actually interested in seeing how it performs on X8 config as the blades are much closer which make it ideal for coaxial setup. (or maybe its just me)
This is a New Photo of our Quad with the T-Motor 15 x 5.5 CF props we tested.
Cheers, John W.
I think the Gemfan 15x4 is the best ....
The most important factor to consider is that adapters raise the center of mass inside the motor so any imbalance is magnified. Imbalance does not just come from the props. It can be the result of differing resistance across each winding phase. The best use of these adapters is so that you can use smaller props such as the 14x4.75 Slow flights because they will deliver better performance in high winds. The optimum lift efficiency is not the best for stability because rpms. get to low in the descent and yaw. That is one area where SR's are much better because the idle up function keeps head speed at a constant high throughout the flight.
If you run the head speed too low on a SR you will see MR type instability as partial blade stalls occur.
As with Full size heli ops. you can get a natural frequency harmonic that will create vibrations out of nowhere, these will often go away just by a slight change in head speed. With MR's it can also occur but you can't simply change the pitch angle without changing the prop.
In a rarified atmosphere the envelope for finding the best all round prop. will be smaller. It could be that your motors don't have enough KV to allow for the higher rpm that is needed. Adding pitch is not the answer as it will induce a blade stall, That sounds like what is happening now. you need less pitch, more blade area and higher rpm but I don't know where you can find it.
Pete
I have not had the time to test any MR's recently but I expect that a 15x4 from APC would be a very good prop. to start working with.
