@jes1111
You will have to redo your science. High pitch props (prop is fixed on the aircraft, aircraft at airspeed 0) will stall if the rpm is too high, but they will work (not stall) for low rpm. That is why people start their F5B (with e.g. 18x19 props) planes at 20% throttle. Thrust is produced as a combination of the "swept area" of the prop and air accelerated in that area. For a given pitch of the prop you can raise rpm to accelerate more the air , or you can do the same with lower rpm and a prop with higher pitch. If only the "swept area" would be the key, take a 14x0 and give it a try.
pitch-ration above 2:1 and "dangerous territory" is true coming from rc-planes, but not true for multicopter we run them at much lower rpm, than they run on planes.
Your link might shows basic info, but this is for sure not a scientific source of information. If you write this as an article in a scientific journal, they (including myself) will cut you into pieces.
I am flying the 14x8 in a wide range of load, I am using the 15x7,5 from foxtech, I also flew the Aeronaut 13x9 on the quad (which would work even better (more thrust
), but I am not able to balance the prop to get nice videos).
Yes there are zip-ties, Take a NX-motor, take a 14x8 and show be a better (more balanced way) to mount the prop on the motor. Just for your curiosity, the prop will also work with only one zip-tie, even more it will work (for some time) with no zip-tie.
best regards
Ferdinand
