OK.. I just updated the HD55 firmware folder with firmware called:
2012_02_22_P3X_HD55_STD_X3DL.hex
and
2012_02_22_P3X_HD55_PRO_X3DL.hex
These are found here.
Attention while using them !
No need to factory default.... just reduce your I and D faders, and adjudt to suit.
Dr.Ray - Your (5th) remark.... Do not bump acceleration so high... same reason as posted above.
Dr.Ray - Your (6th) remark.... This function works like so:
If AUX1 is brought to less then -300uS from centre, goto home is activated.  You still have some control of the mount, but the gotohome is trying continuously to do its job.
If AUX1 is brought to above 300uS, E-Stop is activated, and bringing ( or toggling ) this switch/knob/etc to this value again will restart the servos ( abrubtly !! if the mount has moved by itself ).
This makes this function possible to use by 2 position switch and also 3 position switch.
( until this is refined more in next firmware being done )
BTW.. there are small arrow markers in the Functions Tab - > Functions -> AUX1 and 2 level meters, to show approximately when the triggering takes place.
Seattle -  4) How sensitive is the magnetometer to surrounding servos/motors?   It's now set to medium sensitivity. Any motors, servos , magnets, ferrous materials that change the direction of a '
compass needle'  placed instead of Picloc, will undoubtly have a negative effect.
Let me explain.... Imagine as if someone blindfolds you and is turning you around, but is telling you continually that you're heading North ( a strong magnetic field close to Picloc that is 'masking' mother Earth's subtle field).
You will have the impression that something is not right, as you feel you are being turned, but something/someone is cheating.
DJI/Robbe Helicommand PRO,  have put their MAG compass together with their GPS out on a stick for this reason.  However, this was impossible for me to make with Picloc. Imagine a 6 to 9 inch stick pointing out of your camera mount ( sounds complicated isn't it
With the help of a compass needle, a good place can be found for your mount on your pan arch ( if tilt and roll are proportional ) so that the Mag can be switched on.
BTW.. DX7 working properly now ??
GarageLars - Can not find anything else to adjust.. worked fine before FW update.
IN Functions -> Proportional, there is an adjustable control for your Proportional stick inputs for the three control axis.
This function needs to be refined.
DKtek ... hmmm... Can't check right now, but last time I had it running, the Artificial Horizon was working. Promise to fixit if its not working.
Boris .. YES please!!!... I wish I could do it myself right now.. but I just cannot !!
Sorry for lack of replies right now.... really hectic at my day job the past 2 weeks and this week.
Thanks for now. Be Back soon.
George
