BorisS
ray if I send you my email via pm can you send me the 55HD version with acceleration activated ?
Boris
GeorgeM
Hi PPl... My site was down , then back up for some time.....and now it seems down again.... Sent initial email to my ISP support but no replies yet...
Regarding the issue of Proportional control lack of range...
Know about it.... it's related to the change in Servo output resolution.
So.. I had added a second Tab in Functions, called Proportional.
This is a volume control on your proportional stick inputs. If it is not enough, I can fix this by firmware very quickly tonight.
If my website is not up yet, I'll make firmware down loadable from somewhere else.
Thanks - George
peterd
Hi George,
ifyour site does not work so can not run PilocTolz?Or should I install something wrong?
To date,I dowork
Peter
BorisS
I am able to start picloc toolz some or not, did something change from the different version ? concerning server side applocation etc.
Boris
George,
I played with the different proportional settings, but there was no effect.
My Av 200 only traveles 3mm to the legt and right , while stabilisation works all the way.
Is it also because of the new servo resolution that my slew servos wont go fast any more ?
Jochen
GeorgeM
Jochen... Ok... I'll fix this asap.
Multihexa....>The tool can not be started unless the website of George's.
You mean.. you can't download it !!
Toolz will work without an internet connection ( if it has been already been downloaded and installed as per the usual case )
BorisS
I cant remember having the option for local or serve side installation. Cant run the install files at the moment since they are surely linked to the server.
Boris
MultiHexa
George
I can not run the tool on my PC.
I start PiclocToolz-3X v.E055.application and there is an error message that I should test my online connection. Yesterday everything has worked.
This message is always:
The application could not be downloaded. Check the network connection.
But I have installed the PiclocToolz v.E055-3X. Why the tool will always have an Internet connection?
Can you send me a version that runs without an online connection?
It is important because on Sunday I have a job where I must use the Picloc.
I still have set the Picloc on the camera mount.
I had already written to you today an email (AeroMovie).
BorisS
Video for acceleration variable explantion, like promised for pushing out a FW version that fast were is enabled again :)
Boris
MombasaFlash
Heli's & Tele's bloke
As Rotorpics is still not back online and George is far too occupied to answer emails, does anyone know what is the maximum voltage the 3X will stand? I ask because, when powering the AV200 Pro servos with 7.2v, wiring will be a lot simpler and the whole installation less cluttered if the 3X is happy to run on 7.2v as well.
PaNt
Yeap you can... 9volts is the max
peterd
Hi,
no information when someoneis restored to the server George pages...I would like to workwith PiclocTolz.....
Peter
Boris
Hi Boris!
Correct me if Im wrong, but I think George pointed out here and there that "Smooth" or whatever its labelled now, is only for 360, not proportional servos. (without potentiometer)?
I can absolutely be wrong, but the descriptions can be a bit confusing...
//Lars
BorisS
japp I am not 100% sure but you are right I guess smooth never really gave me any difference on a 2 axis, but that wasnt really the point. I just wanted to clear up the misunderstanding with acceleration, i shouldnt even have mentioned smooth :(
Boris
