i get them at Altitudehobbies.com,,, these are the 2810 version
http://www.altitudehobbies.com/brus...ess-motor-peak-450-35-28-1000kv-suppo-2810-12
that red line about using 4s is me,,,,,
these will hover all day long and lift alot of weight on 9", but there a 1000kv motor,,,,,, the 9" on 3s might be better than on 4s,, i know the 10" on 3s were great, just didn't do the wind as well. if your still light like 1500g, the 3s and 9's are probably spot on, your looking for a hover at mid throttle in manual mode,,, that's how you see what you got and where your at....
The 330's are fun, never tried a suppo on them, but i'd probably step down to the 2212 size, 8" prop on 3s should be fantastic. There so light it doesn't take much to fly one... i'd do these
http://www.altitudehobbies.com/brus...ess-motor-peak-400-28-30-1000kv-suppo-2212-13
honestly, i've painted 12 of these now, all i do is mask off the wires, scotchbrite the chrome off so it's dull, scratch the gold annodize and hit it with this
http://www.tooltopia.com/sem-paints...=cse&utm_term=SEM39673&utm_campaign=nextag_r1
it is black so then your done. i got the green version and it takes a color coat over it... just spray it even so it doesn't get out of balance
I'm not stumbling on a suitable prop adapter, sit tight, let me sort this out.... Do you need graupner props too? or running something else? i found 4mm that fits teh motor, but 1/4" shaft... apc fine, graupner, not so fine
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMSF4&P=7
