That is what I would have thought but then when they show this image it seems to contradict this. Also: they state that it should not be mounted near servos so if I can't mount it as they show here, down low on the right, the only other place is up on top and there is a servo and pot right there.
There is no box...because we typically dont use them on our controllers. Same as MK
Ok, but I could cover it with heat shrink tube or something like liquid tape?
I am asking this because in the manual says to be carefull with heat when calibrating gyros.
Another question: is there is a difference in performance using 5,5v instead o 6,5v or more?
Thanks for your help.
I am trying to program the Hoverfly gimbal in the Configurator but I cant get the Scaling Factor setting to work properly in Roll. I can level the tray with a bubble level with the gear flat on the table in front of me but then if I pick up one side of the gear a couple of inches (left or right side) the tray will not hold its level position and needs to have greater deflection. If I try to dial in this deflection with Scaling Factor to get the bubble back in the center the roll will go just so far (and not nearly enough) before it starts to freak out. I read that this might be due to the gain being too high so I set it to ZERO and it still does the same thing. The pitch setting for Scaling Factor seems to be alright but this Roll setting will not work and my camera tray will only sit level if the gear is level on the table. As soon as I move it either way it needs greater deflection. I did play around with the min. and max. pulse width to be sure that the servos would not bind the movement of the gimbal in roll as suggested in the manual so I don't that it is related to this setting and they seem to be correct. Anyone have a suggestion for this?
Today I received my hoverflygimbal and am setting it up. For roll I only needed 5min to get it right, but I don't know what is wrong with the tilt axis. I tried a lot of settings, but every time I tilt my octo (hoverfly mounted frontbottom) the tilt tray is going way way faster that my octo is being tilted/pitched. When I turn down the scaling factor(even to zero) it goes a little slower but still not even close. I also 'waits' a half of a second before compensating the axis, increasing gain only makes it even faster overcompensating.
I have an av130, who can help me out with this? Provide me his settings? Or have I done anything else wrong?
Is this a joke??
I just got off the cursed skyline and was convinced this was better, now I'm in the next problem. I even asked hoverfly if there was absolutely no problem with this product, they should have mentioned it!!!:upset:
Can't it be the potentiometer? I need to decrease the scaling factor to get it level and also increase the 'setlevel' to get it straight. This was a problem I got when I used the standard outputs of a borrowed naza. Maybe that's why the roll works, because this potentiometer was at it's good point?(the potentiometer I removed for assembling the skyline was at it's wrong point). Maybe I can get improvement here?
My tilt tray point everywhere except for straight forward.
Photohigher isn't telling that much. They only come apologize every once and a while. But the thing that is getting me frustrated most, is that they told me nothing was wrong with it.
I have 2 expensive units, and for that big amount of money they don't even work.
Potentiometer didn't improve a thing..
Here is a video I just made (sorry for the out of focus, but shut everything down after I checked the video. I should be able to get any improvement if I look at your video psionic001, my scaling factor allready is low.
Uploading should be ready any second.
How about any previous firmware of the hoverfly for 2 axis stabilisation? Will that be any good?
