Im connected to the Ninja plate from Freefly. There were no holes for the toad in the hole to screw into so I thought the plate would give me better mounting.
The legs are longest ones from aeronavics.. hate them, can't seem to handle the weight well at all.
You are correct... gotta have the movi back centered for landing.
Ok, interesting.
I actually bought the freefly MR legs, but I hated the way they would spin if you had the slightest bit of wind during take-off.
I was really worried about not having 360 with my legs down, so I cut the extra Pan tube that came with the Freefly MR legs to allow 360, as it would be very dangerous if something happened during flight and you could not get the retracts down as you didn't point directly forward.
Not sure how long you have had it, but try yawing when flying fast forward and see if you struggle with the yaw.
I just drilled 4 holes directly to the skyjib plate and mounted the toad to that, and it seems ok, so maybe your extra plate is maybe moving?
Landing with the extended legs is a bit hairy, I think that the skids are very small for the height of the legs..personally.
The Freefly MR legs were great for landing take off, very stable but I just could not get used to the constant having to kill the gimble to make sure it didn't start into a wild spin.
