I don't usually make posts, but I think I need to write this one. I have had a Droidworx SkyJib 8 for about 2 years, with a Wookong-M controller. I have never had any issues with it. Recently, I decided to build a Gryphon hexa and bought the new DJI A2 controller. HUGE MISTAKE!!!! I do aerial video and photography and I have a lot of experience with RC - planes, helicopters, multirotors, etc. After carefully building my new hexa and installing the new A2, which I thought would be superior to my trustworthy WKM, I made a few test flights, tested RTH, and all the other functions I had set up, including the channel mapping for the gimbal, lights, etc. Yesterday, I had to shoot a video at a public event. On the 5th flight, the A2 decided to throttle up to full throttle, and climbed like a rocket. I had aileron and elevator control, but absolutely no throttle control. My first reaction was to switch to Atti mode, which didn't do anything. Then, I decided to switch to RTH, which didn't do anything either. At that point, the hexa was over 100 meters high, and my only thought was to turn off the radio to force a FS, and therefore, a RTH. Well, the A2 decided it would just cut the throttle and come straight down. On the way down, I turned my radio on again to see if I could get control again. Nothing happened. The hexa kept coming down with the motors at an idle speed. The A2 kept the hexa leveled but kept coming down really fast, until of course, it hit the ground. My brand need Gryphon hexa was totally destroyed, as well as my camera mount. Fortunatelly, it didn't hit anyone or anything (like a car). The event was on a wide open area. In summary, what I'm trying to do with this post is to warn anyone who is considering to buy a DJI A2, to NOT do it. Tonight, I decided to search the web to see if something similar had happened to someone else. To my surprise, other people have had very similar incidents. This means that DJI and its distributors keep selling the new A2 KNOWING that there is a problem with it. I must add that all my A2 modules had the lastest firmware. My recommendation is NOT to buy the DJI A2. I have the iOSD log of the flight with which I'll see if it's possible to find any information that may show a possible cause of the incident. However, I'm never using the A2 again...
Sent back my A2 because at that point it did not have waypoints. Was flying my Octo with a Naza2 very successfully until.....the thing went nuts and did not respond destroying my beautiful octo and gimbal and camera. The most irritating part is how DJI is handling it; basically avoidance. They reply and then ignore me for weeks at a time. Good luck Javier as DJI doesn't seem to give a hoot about pro users. Anything can malfunction but what separates top companies from buffoons with ShamWow hawkers as reps is service and clearly at this point DJI is sinking fast.
What FC are you using now?
@Javier,
sorry to hear this bad news.
Can you post some details on your configuration? There must be some components or incompatibilities between components which are causing this type of issues...
For example in the German FPV forum there is a big discussion on the compatibility of DJI stuff with PPM receivers, especially in combination with Jeti.
DJI support made some statements that if you fly with PPM receivers you are not fully supported and recommending to use only Futaba or Spektrum.
While flight testing my A2 controller I came across a bug in the POI function.
I was testing the POI function for the first time. I took off and flew about 100 feet away. I toggled the IOC control and recorded a point of interest. I then moved the craft off my POI hover point and then did three circles around my poi and varying distances. Everything so far worked exactly as expected and the same as the Wookong.
Next I turned off the IOC and continued to fly to a different spot on the field. I then wanted to verify that I could switch back to POI and have the craft turn to the previous recorded POI. When I clicked IOC switch to the POS position (middle position on the toggle for me) The S800 instantly started turning toward the POI and started rocking back and forth violently. It looked like it was to flip in the air.
As soon as I could, I turned IOC switch back to off and the S800 went back to a normal hover. After the IOC was turned off the hex flew as normal. I flew it back closer to me and tried hit the POI function again. Again the hex went full forward and then full backward, then full forward again. These were very aggressive movements.
In the video the violent movement of the hex is not well seen as the H3-2D gimbal does a great job of removing most of the frame movement. The second time it happens you can see one arm coming down into frame for just a second.
I am disabling the POI function until this gets resolved.
S800 EVO with A2 Controller (version 2.00 Beta software), IOSD II, H3-2D gimbal. All gains set at 100.
Here is video from the flight...
http://www.youtube.com/watch?v=cvWQtWJmh3Y&feature=c4-overview&list=UUtsQBn8sezLXKHA2xYswdWQ
This negative feedback about the new A2 is all very distressing to me as I have recently purchased one for my new Octo and am losing confidence in DJI.
If this were a western European or North American manufactured product, it is possible that a class action suit would already be initiated ....
Free enterprise and capitalism thrives when there is a full circle feedback mechanism such that manufacturers listen to the customer's concerns and responds so that they can maintain their position in the market.
But except for some HongKong businesses this concept has not been fully embraced by Chinese manufacturers.
The FAA, TC and others can be expected to impose signficant constraints to hamper such businesses where there is evidence that the manufacturer releases dangerous products to the marketplace.
Javier what software was your A2 running at the time of the crash? Were you using the gimbal outputs from the A2 controller? Others were reporting problems when they used the gimbal outputs.
There are two versions of the firmware, V1.00 and v2.00. Both are labeled as beta. It sounds like yours was setup very similar to mine. The only difference I see is I have the DJI video transmitter and Futaba 8FG radio. I picked the 8FG radio because I saw early on that DJI seemed to prefer those radios. I will wait will the a stable release of the software come out before I test the RTH feature!
