Hi all,
the last two days we had very ugly weather (lots of wind, rain and freezing coold) but Sebastian's Team managed to do some test flights.
Here is the data:
Quadrocopter with different weight and propeller configurations.
- Axi 2814/22
- 6s 4200
- 11x5; 13x6,5
- Droidworx AD4 HLE
- Weight 2,2Kg up to 3Kg
Herkules:
- AFW 1
- 24 Deg
- 8Khz
WKW latest FW from 11.1.2012
No power sourges at all, we had strong wind with up to 35 Km/h so no smooth flying but the height control in ATT Mode worked really good. With the Big Props and NO payload I needed around 15% to hover so the AFW was not enabled so we tested the limit of the activation of the AFW but had no surges.
We will go on testing further on if the weather gets a bit better and do also some movies.
Fact up to now: with this Quadro-config we had no issue at all, even with AFW=ON and very low load. So i think Active freewheel is not the bad guy here!
Now we have 3 more possible failure root causes:
1) The connection of 2 x Herkules together in an Octo System causes some trouble, e.g. Ground offets and false detected PPM signals?
2) The DJI Firmware is still buggy and can't get with a very fast ESC as the Herkules is, yet?
3) The Attitude Hold of DJI causes some problems?
=> As we don't have an Octo DJI System up to now we can not test right now. We will build one soon. Maybe we will meet with Boris again and search with him on his System.
As i am the "Advocate" of the Herkules, and looking to the facts right now i cannot find it yet guilty. Maybe we will have to blame somewone other ;-) I am sure we will find the problem soon.
Question to all: Did you check if the surges are present in Manual-Mode?
