Dear fellow multirotor-flyers and/or builders,
this is my first thread on this board and it's written in desperation. After many hours of trying and testing every tipp or hint I found on the net and in the Naza's manual, I'm a bit frustrated as I can't get my Naza F450 to work.
My F450 is all set up and built, but it just won't start if I try to use one of the CSC "startup-gestures". When I turn on the whole system, all ESCs do beep two times and then do this 1234-melody (or is it 12345? I guess you know what I mean). But one motor beeps more often for a few times (without any "melody") before it does the melody as well. I've seen videos around where people don't have one motor do this additional beeping, but I couldn't find out what it means.
I followed all instructions in DJIs manual and allready asked about it on a very helpful german board, but still couldn't find any solution.
Just a bit of background information:
- I updated the software-assistant to the newest version and it works properly
- TX is Spektrum DX6i, RX is Spektrum AR 6200 w/ satellite. Rx and satellite state they're connected (LED is staying on). Even tried and bound it to a OrangeRX, but that didn't make the CSC motor-start-gestures work neither
- In the software, Motor Mixer is Quad-rotor x, Tx is calibrated, no channel is on reverse accidently. Receiver Type is set to Tradition, Cut Off Type is set to Intelligent (tried "IMM" as well, didn't work either)
- U-Channel is calibrated for a two-position-switch on my Rx, position 1 is Atti-Mode, pos. 2 is Manual mode
- I tried different settings on my Rx, including trimming and no trimming and expanding travel up to 125 % - still no reaction to the CSC
- Rx and Tx are bound, no errors on the naza assistant software. LED of Naza VU is flashing yellow every few seconds, indicating atti-mode. Tried to start in manual mode, too, but without success. When I perform one of the CSCs, the Naza-VU flashes yellow two times (at faster speed, telling me that I made some unkown input) and then continues to flash as Atti mode.
- When I connect one of the ESCs to the throttle-port of my Rx directly it powers the motor well
- I even tried to power up the ESCs first and the VU second, to give thos ESCs time to initiate - no success
I even tried the different settings like voltage meter on/off, IMM/Intelligent mode, and so on. I really don't know what to do next. All those older threads I found on the net, posted by people with similar problems, were resolved by one of the stated steps I took. But unfortunately they don't work for me.
Every hint, tipp or trick is appreciated, I hope someone can point me in the right direction.
Best wishes,
EE
Best wishes,
EE
