Ohhhh Mr.  Mikeq
I am not sure why you didn't read the guide/tips info we sent a long with the gimbal.  It clearly stated DO NOT USE THE DEFAULT function, it will erase all of the setting we put on there (like you mention in the PM).  Once the setting is erase and if you don't know what you're doing, it isn't going to work again.  Secondly, for further help, please send us email directly, sending PM here we can not reply right away.
-  The instructions also said the gimbal will only work WITH THE camera on it... It also said the gimbal was tuned for a Nex5 with 18-55mm lens.  Does that lipo weight 1.1 lb?  If not, there's 1 issue.  Without the proper weight/power of the motor it will make small vibration that you can't sense it and could increase the drift problem.
-  Upgrading it to latest version without understanding what the newer version does and how to tune it again is a disaster.  You mention after upgrading to 2.4 the gimbal shake and jerk... well here's the problem.
Quote from the upgrade log
"Up to 5x more precision with the new PID (increase I-term until  oscillation starts and than reduce a little back to get the maximum from  it)"   So you need to start with the lowest number possible...   .01
- About the gimbal break away in yaw showing in your video, I am not quite sure what the issue is.  But I think it probably the Follow Mode, we set the gimbal with Follow Yaw mode enable.  It only stabilized a few degree then once pass that it will follow.  In your video, you move yaw back and forth quickly and way pass the small yaw movement it's correcting, then it start doing the follow... but then you turn it the other direction so quick, that might be the problem.
