araines2750
Hexa Crazy
DJI Link & GCS questions answered from Terry at DJI
I wanted to post to the forum the answers I received from DJI about the Link & GCS,
I hope these help others with the same questions.
1. How do you fly a mission without internet connection? How does it get thebackground Google map? I hope to take everything to a different locationwithout internet, but am not real sure how this works???? I have seenstatements like you must Cache the map. How is this done?
Zoom in area where you fly firstwith internet first. GCS will go to offline mode when flying outside.
2. If you are flying Via GCS (900 Mhz) Single waypoint- Click & go and flybeyond the range of the traditional TX (2.5 Ghz) transmitter what happens? Doesit continue to fly and be controlled via the 900 mhz. link or does thetraditional TX signal loss trigger the failsafe settings (RTH)?
GCS takes in control in stead ofTx, no matter Tx signal lost or not.
3. If the aircraft loses the Link signal (900 Mhz.) and not the Traditional TXsignal (2.4 Ghz), what happens?
RTH in 10-30 seconds
4. If the aircraft loses Both the Link signal (900 MHz) and the Traditional TXsignal(2.4 Ghz), what happens?
5. How do you adjust the rate of assent / descent in GCS? It seems to climb veryslowly.
Adjust Vertical Speed inWaypoint setting
6. Can you fly entirely with 900 Mhz link & GCS and without a traditional TX?If so, how is this accomplished?
No. Must have Tx.
No. Must have Tx.
