TBS Discovery, FPV Quadro from Team Blacksheep based on DJI Parts
ah got it:
attachment.php
meme
Huuu Kloner, 16 minutes??? I need those 9" Graups!! And some Axis maybe, don't think that the DJI`s will carry another Lipo, have you ordered yours, Boris? Someone knows where to buy the 9" Graupners?
I've ordered those Siliconpads too, but i don't need it anymore, have a look (filmed in 1080) This is Raw Footage, no Post Stabilization:
It needed couple hours to figure out hoy to eliminate those Vibrations, but the only movements now come from the high gains and me fighting with the Naza GPS-Drift.
This is how the Mount looks now: View attachment 4879
cheers, meme
i get 10 minutes on a 4s 3000 mah pack, and still got 800-1000 mah left.......
My frame is in customs, should have it any day now. Where are you at?
theres still a little jello, but it aint bad at all. definately fpv approved!!!! i hate flying in 1080, rather use 960 for the top and bottom half of the field of view..... instead all i see is black letterbox. Gains sound a whole hell of alot better
i use these motors
http://www.altitudehobbies.com/brus...less-motor-peak-480-35-36-1000kv-suppo-2814-8
v-east has the 9x5 in stock, same with multiwii in au http://www.multiwiicopter.com/products/prop-9x5-graupner-e-prop-1326-9l-multicopters-l-r-cw-ccw-set-of-4-props
meme
Thanks kloner, i have to balance the Props always, maybe that bit of Jello will vanish, will try some post stabi on that file also. As for mah Consumption, is it possible that the DJI Motors will consume much more than your Axis or is the higher consume only Prop-related?
As for Props, thanks, will check before if someone in Europe has it on Stock.
Think it has to do with the motors fitting the weight and using the 9's.
i've got everything ready to swap all this straight over and gonna switch up to the 1.3 vtx then. needs 12v i don't have to offer it now
pretty much what you got
that multiwii place is about $3 less a prop than here, but it's international shipping. i ordered 16 props or 4 sets and it was cheap in the end
azure
according to trappy, any foam setup will tame it to 720, but if your after 1080p with the gopro, you need that sheet. only need half, wish one of you guys wanted it in the usa, i'd split it with ya
If you think these pads REALLY work considering the price, I'd split them with you. We're both in CA, so easy - PM me if you want to do it.
This is how the Mount looks now: View attachment 6576
cheers, meme
meme i got/have these axis and the props from http://www.electricwingman.com/graupner-elektro-propeller-9x5-pair.aspx and
http://www.electricwingman.com/axi-2217-20-short-shaft.aspx
these could be very interesting though but they won't increase flight time, just for some extra punch http://www.electricwingman.com/model-motors/axi-2217/16.aspx
I also have these on the way: http://quadcopters.co.uk/torxpower-2216-pro-short-shaft-brushless-motor-900kv-330-p.asp
and I was looking also at these http://www.multirotor.co/product_info.php?products_id=123.
but they are all not motors for a longer flight time and i will be running them with 10 x 5 graupners at the beginning.
meme
Thanks Boris, my 9" Graups are on the way now. A local dealer here is closing his shop and offers me the E-Flite Power 15 Motors, the should be similar to the Axis?
I need at least 10 minutes of flight time with 20% batts left, so i like the setup of kloner pretty much. @kloner, wich ESC`s do you have in use?
e-flites are usually pretty efficient, just not the most powerful motors i've messed with. mine are whats known as 480 size motors
am using the dji 30 opto
meme
My first Gopro-Footage from a FPV Flight with the Discovery:
meme
Finally i made one of my favorite Mountains around here- with the Discovery
was waiting for ya to kick it into manual and shoot down the rock. Man, that's a big sheer cliff
meme
thanks for your comments! i started with MR only in january and have flown the Discovery only in GPS Mode for now, In fact, i had some trouble to bring it back from such a hight in strong thermal currents :) I will exchange the Atti Mode on the 3 Way Switch with Manual mode now and learn to fly (and descend) manual. The surrounding Mountains here need def some low&dirty, Zeph-like descend with the Discovery, right.
meme
Hello all, i am back from Vacation now,missed the MR Forum :)
Had a blast with the Discovery and lovely FPV Flights:
cheers, meme
that blue water sure has it all islandy looking. Good job
whats the abandoned looking area around 3:00
Love the offshore part, the risks were worth watchin
the land part of that looks almost exactly the same as here in SD
