XAircraft XAircraft X650 Pro - Owners
X650Mouse
Take no prisoners
I think its a little foolish to release a gimbal with out any footage or video of the product. Maybe its still to early, or it hasn't been officially announced?
But with all the claims, I'd like to see some footage of it in action in various settings. Seems interesting...
It's only in pre release mode, no price mentioned and I am sure they will do a video (s) for the release.
David
Aerovideo
I'd buy a gimbal for a dollar without seeing it in action ;)
Actually, I made an impulse purchase of my GoodLuckBuy 3axis GoPro gimbal without seeing it in action and it turns out to be a decent little gimbal.
X650Mouse
Take no prisoners
Hmm! I have a bridge in Sydney harbour for sale, not a dollar! how about $1,999.00 I'll take PayPal or direct deposit :nevreness: you know you want it, be the envy of all your mates
David
Dhardjono
Can share a video of there 650 pro with any gimbal s flying i want to see if you all have same vibration jello like video . i am getting lots of vibration . The gui is 1.0 if i bring it up or down will it eliminate some vibrations. Fustration dude i am chatting now with Hobby Wing try get some answer.
Aerovideo
David
Wow a bridge for only $1999! What a deal!
Now if I could only remember my Paypal login ;)
Dhardjono
Looklike no one has any video to share yesterday i went out my gps came back here a video of it the super x did a good job of holding position at wind of 5 to 10 mph
also try setting gui at 1.5 on all the gains and it made it worse vibration.
wbrownj
Well there is a raging storm outside my window here in London and so I finished up some bits on my xa650 Pro and thought I would post a few pictures and videos for you.
I appreciate any comments etc. especially should you see anything that is 'not right' !!
One question I have is that all told, the take off weight is 2.34Kg. Is that too much? I run on a 5000mah 4S lipo.
Here are some pictures:
Here is the quad with new and somewhat standard fluorescent yellow boom wraps. I used to have white, but really the yellow looks better and is more visible against the sky. Hanging off the front is the gimbal, but more on this later.
This picture shows how I have configured the component placement. It all seems fairly neat to me. Further to a recent question I posted, you can see here how I now have the auto-pilot oriented.
So here is the new gimbal. It is from GoodLuckSell and it slides directly onto the hanger tubes which makes for easy mounting and removal. It is not a bad gimbal and worked pretty much out of the box once I had worked out the best way to position the GoPro. The gimbal is a bit deeper than the smaller ones and can accommodate any model of Gopro (I think) so for my GP3be I ended up making a Styrofoam block at the back to support my GP and then used a Velcro ribbon to secure it.
This is my Gaui GV100 FPV system which now sports cloverleaf antennas. Because of the weather I have not yet tried them. FPV remains new territory for me so when the weather breaks (if ever) I look forward to giving it all a go.
Here are my two ubecs. One is for 7.4 volts to power the lighting system and one is for 12v to power the gimbal
Here is a look at the gimbal when it is off the quad
Originally on the top was the exposed controller circuit board but I thought it would be pretty susceptible to moisture if it started to rain when I was in flight so I used duck tape to make a cover for it.
Finally here is a back view. This shows two sets of cables. One set is for power and the other is where I have added a connector plug for the video feed. This permits me to leave the GP in place and still be able to remove the gimbal just by disconnecting two sets of wires and sliding it off the hanger rods. That in itself is pretty convenient :)
Here now is a video of the beast....
Note that there is a little jiggle in the gimbal, but that is really a factor of me holding it one handed while trying to keep the video on target with my other hand... in reality the gimbal is pretty darn steady.
Finally, for the FPV monitor I have made a visor to help visibility of the screen in bright daylight. Again, not tested but is seems like it might be good. It is mad from the plastic cover of a ring binder folder and has been cut and creased into shape. It attaches to the monitor with Velcro and is therefore easy to install or remove and also it fold completely flat for easy storage.
If you have any comments or suggestions I can always learn from your experience.
Enjoy and Merry Christmas one and all.
Jonathan
Dhardjono
Looks good Wbrown i like it i like those lights what gimbal are you using . i like the light signal in the back for me so i can see which is the back side but that just my like. I like to see how it fly i added mouse pad under each motor just to see if it less vibration but from dji face book forum Richard sugest to get this http://www.goodluckbuy.com/fc-unive...-quadcopter-hexacopter-carbon-fiber-tube.html before that i will try this mouse padding than try the tarot gimbal and carbon fiber props. Have fun with it look good all around and Merry Christmas to you too it also raining here in New York so no flying it warm 55 degree oh well cheers.
1 more thing i try these nano tech turnigy 6000 amh which give me 15 plus min's and 2 min to land this is with out my 6000 amh tx but with arris gimbal so i like these they are not so big in size and weight and give me good time althought i was flying slowly it might give you less flying aggressiveView attachment 15289View attachment 15290.
wbrownj
Hi Dhardjono,
Thanks for the reply. The lights are really good but those are like headlights and would look weird at the back. Perhaps I could find some tail-lights too !!!
I am not sure of the model, but the gimbal is from Goodluckbuy / GoodluckSell. Its not the smallest thing but it does seem good enough for my needs anyway.
Thanks for the tip on the batteries, I will look in to them.
How much does your complete rig weigh at take-off?
Mine is 2340g and I want to know if that is too much.
Jonathan
Dhardjono
I don't have any weight measurement but the arris gimbal is 17 g battery is 623 g did not have my fpv tx but that weight almost nothing and basically i have all what you got with oisd for fpv telemetry &View attachment 15295View attachment 15296 only i use sbus for futaba tx so less wire and i have 1 ubec for the gimbal which weight nothing and no lights.
wbrownj
Thanks Dhardjono.
Can anyone else comment on my takeoff weight of 2340g?
Is it too heavy or does it sit within the acceptable weight ratings? I don't want to over-stress the motors or escs.
At that weight, what sort of flight time should I expect from a 5000mah 4s lipo?
Thanks for your help and merry Xmas
Jonathan
X650Mouse
Take no prisoners
Thanks Dhardjono.
Jonathan
XAircraftAustralia specs for X650 Pro
TAKE OFF WEIGHT (TOW) AND EXPECTED FLIGHT TIME
1800g (including 4S 5800mAh LiPo battery) 20 minutes
OTHER SIZE AND WEIGHT SPECIFICATIONS
  • Frame weight only (no power unit or flight controller), 535g
  • Frame with power unit (ESCs, motors and propellers), 1075g
  • Frame with power unit and SuperX Flight Controller, 1265g
  • Maximum gross TOW (do not exceed TOW), 3000g
  • Maximum payload, 1735g
  • Diameter, 570mm (from motor shafts) 645mm (motor mount edge)
  • Height, 270mm
  • Hangable height, <157mm
  • Approximate shipping weight (complete kit), 2500g
David
VIQuad
Mouse pads....Let us know how this works out. I thought about trying that a while back but never did. I was worried it would throw off the balance and leveling of the motors, seeing that the motors wont be sitting 100% level on the pads. I also considered a moongel pad. http://www.percussionsource.com/p/r...ing&aff=5110&gclid=CKS-k67NyLsCFfPm7Aod_0UAUw
I'd be curious to see the before and after video, post something when you have some results.
Emowillcox
I have had good results putting mouse pad under my camera on my gimbal.
Jonathan What kind of fpv monitor and bracket are u running?
X650Mouse
Take no prisoners
I have used Moongel under my Hero 2 with a 2 axis gimbal and it was the best of a lot of different material uses, now using the Arris the places to use are limited and not really sure a requirement.
David
Dhardjono
Yes i will try to go out today i got my fpv tx yesterday from mail i hook up ready to go it cold today but i am willing to try 1 or 2 battery also i email xaircraft america they been giving me advise and reading my black box report i got some tips from him. if mouse pad don't work i will try tarot gimbal and if that still don't work i will try anti vibration landing skid.View attachment 15302
