Yes, progressing very well. Have some tuning to do with the new GotheliRC VX5 gimbal. Total weight excuding battery and fpv equipment is 1900 grams.
View attachment 18555View attachment 18556View attachment 18557View attachment 18558View attachment 18559
Kloner:
I haven't decided on a discovery frame or not yet.  I'm testing with a f450 body with heavier arms now at 550mm.  I'm looking at mounting the same gimbal that Boltzman has on his discovery.  I'll be running a little heavier camera then the nex5, either the gh2 or Black Magic Pocket Cam.  Gimbal & BMPC with light lens is probably  2.2lbs the way Boltzman has it mounted.    I'm just concerned about the prop wash hitting the bigger camera/gimbal.  I always mounted directly under bottom plate, never up front.  Brushless gimbals are hard enough to setup in clean air. Will know soon enough.
With this setup, I'm testing on a 550mm standard quad with 14" props on my Avroto's 3515 (borrowed 4 from my x8) for testing.  Avroto's are basically same as u5 and have the same prop mounting.  I'm getting great flight times with 6s , 8000 mHa battery with the go pro and expect low to mid teens with the 2.2 lb gimbal/cam setup..
I'm also going to test on a 660 mm  quad frame with 21.5mm arms (different frame which adds 1 lb) and 15" and 16" props.
I'm almost convinced to buy 4 more low KV motors, but it's cold and snowing here, so have time for some more testing before committing.  I'm currently using a Naza v2, but just got a Pixhawk.
If it's half way decent, this will probably go on my hopped up quad in the future and won't really need the Discovery frame.  With your 1" clearance, the Pixhawk might fit between the plates. It is 5/8" tall, but wires come out top and sides, so there may be some access issues.
I'm wondering if I could flip your mounts 180 degrees.  I'm assuming you have the 4 mounting holes on top and two on the bottom.  I wonder what would happen if I put (on custom plates) and had the 4 holes on bottom and 2 on top.  This would allow easier access to the Pixhawk if I needed to remove the top plate to get to it.....
Just thinking out loud.
Are 14" props the maximum for a u5 on 16mm arms or can you use a longer 16mm cf tube and go with 15 or 16" props.  Probably in the AUW 3-3.5kg range.   I think on my f450 setup @550mm and bmpc, I'm at 2850g with large 6s battery...
Any chance AMP might be taking orders and shipping this week?
