As a quad n00b and a brand new X650 Pro owner, just wanted to say thanks to all for a great read.
I'll be using my X650 Pro with a Stella/GoPro3+ combo for photography with an FPV camera setup and OSD. Eventually it'll be rigged to be onboard switchable between the GoPro and CCD.
It was a bit painful at the beginning of the thread reading about all the vibration problems, people putting all kinds of utter crap under their motors, etc. while never considering that the $3 pieces of plastic masquerading as props might be an issue... I'm new to this but I guess not as thick as I thought as I ordered some T-motor 12x4s immediately after ordering my X650. Playing around with eCalc for about a week helped me come to the conclusion that the 12x4s would be a good choice, glad I was right from what a few of you have said. The APCs will be used for the first test flights and then thrown into a hole somewhere.Glad that people are seeing good performance with the 12x4s.
Also ordered 4 T-motor 11x3.7s for my Xcope "Pro" (X650 Pro drivetrain) but that's another story...
DroneVision out of Taiwan is a pretty nice source for T-motor products and have a nice selection of props, prop adapters, plates and copper prop spacers, motors and associated hardware, etc. Huge selection of different brands altogether.
If you're looking for T-motor props with a bit more thrust
RCHobbyHelicopter has a nice selection of 10" - 15" T-motor props ranging from 4.5" - 5.5" of pitch.
I think these props are actually cheap considering the quality performance. The props are ultimately where the rubber meets the aether so to speak and where all the work of the machine is ultimately done so I don't understand the lack of recognition of the significance of having quality props on machines like these.
Anyway, glad you solved all the vibration problems and are enjoying your fine machines!
I'll post a pic or two when I get mine built as I've my winter cut out for myselfc with my two new XA builds.
Good luck to all and happy flying.
Best regards
P.S. Forgot to ask some advise if anyone knows...
I get that the XA 30A ESCs that come on RTF and/or ARF machines do not need programming.
Do the individual ESCs sold separately by XA or otherwise require programming or do they also come ready to install and use without issue?
Thanks again!
