Blacksails
Strange. This is the first time I've updated my wkm since 5.02. I've been flying a lot on 5.24 and other than the gps hold not being as locked as it was in 5.02, Its been fine. I've not had it exit into atti mode at all.
I have the same problem with 5.24 and GPS hold. I have tested this both on my quad and my s800 using WKM. What version of firmware is suggested to go back to for more stable GPS hold?
I have been flying two copters on 5.22 and everything is pretty good there.
As much as I love DJI and the Wookong...
They didn't remove all evidence of it. It's still there and lists all the changes 5.24 had. Page 2 of the release notes.I cant believe it they have removed all evidence of 5.24 ever existed ( its not appearing in the release history at all) ..as you guys know in an earlier thread I maidened my S800 - EVO on 5.24 and it crashed..as far as i can justify that it tang amount to an admission of guilt on DJI's behalf..for all those long term WKM users out there have they ever done that before with a Firmware release before? would be good to get a bit of history on the issue of dodgy firmware so i can try and make a case with DJI
Cheshirecat, I am in the same boat as you. I have been flying 5.24 in GPS mode extensively the past 2-3 weeks and haven't observed this either. (Same configuration as you, but on an S800.) It does sound like it's hit or miss who this affects.I am flying on a V1 IMU and V2 Compass with 5.24 on SJX4 and i don't believe i have experienced this dropping out of GPS issue to date.
I flew yesterday in winds gusting at 17-18 MPH over an open field to see how it handled the wind, fought with altitude hold a bit in GPS which i put down to aerodynamic lift as the wind gusted and had to concentrate extra hard on landing holding off until a gust passed, but otherwise i was pleased with the way the rig flew and the zen was very stable. I have seen 2 uncommanded CCW Yaws through 45 degrees, once in the wind yesterday and one previously when flying in a buildings quadrangle where is suspected a swirling effect from the wind against the buildings and i have been monitoring the iOSD output on the down link but not seen it switch to Atti momentarily.
Maybe so far i have just not been afflicted or the combination of IMU and Compass versions impacts this phenomenon.
I didn't see anything in the release notes to suggest anything else had been addressed expect adding the way points for all, as i already have this there is no obvious reason to go to 5.26 for me.
