Old Man
The U8-170 and 28" prop combination will pull in the area of 28 amps at ~2500 full throttle Rpm using 6s. A Wookong FC will not provide stability n any one of wind. The A2 is worse than the Wookong. The system requires more voltage than a 6s system provides to work correctly. 8s will be a minimum if you want the FC to stand a chance in providing any stability with low kV motors and large props. Few have had any success n this area. I have tried it in a quad config and determined that only controllers with wide user input parameters stand a chance of generating stable flight in winds over 5 mph. There have been a couple of private aerospace firm tests that have demonstrated the X8 config to be slightly more efficient than a flat 8, regardless of prop sizing. 5% to 6%.
